Samsung UE46C6700 mainboard replacement
    Did change the mainboard to a brand new one from Samsung. But, the set will sometimes go into standby, through the normal "shut down" routine with the music and all that.
    What the hell is this?
    Re: Samsung UE46C6700 mainboard replacement
    Maybe it needs a firmware update, or reset to factory settings from the service menu.
      I assume it will have the latest FW since the board is produced in 2013.03, but maybe you're right.
        Stuck power button/touch sensor maybe?
          Gosh, think if that is the case!?!?
          Before replacement the set turned itself on and off all random. It's way better after mainboard replacement.
            Well, my bad.
            This time the mainboard was not to blame. When disconnecting the touch pcb, the set does not turn itself off. Also verified by another known good working touch pcb.
            Oh well...
            Is this a common problem on Samsung's?
              It's a common fault with all TVs using capacitive touch PCBs.
