Samsung SyncMaster LD220HD HDTV/Monitor - no power on
  • oddbodd
    • Mar 2013
    • 121
    Re: Samsung SyncMaster LD220HD HDTV/Monitor - no power on
    I've now replaced IC1009 with the LM1117DT-3.3 from CPC.
    The readings are...
    pin 1. = 0.000
    pin 2. = 3.1 to 3.3
    pin 3. = 4.1 to 4.9
    ...which looks better than in post#42. The readings are still jumping around, and still no power on light.
    The other 3 ICs remain the same.
    The voltages across the the connector pins are now...
    1 [B-DIM] 0.0
    2 [15V] 13.2 to 14.2 unstable
    3 GND
    4 GND
    5 GND
    6 [5.2V] 4.2 to 4.9 unstable
    7 [5.2V] 4.2 to 4.9 unstable
    8 [DCR] 3.8 to 4.2 unstable
    9 [ON/OFF] 0.0
    • selldoor
      Slow Learner
      • 7870
      #62
      As all your voltages appear unstable I wonder if your meter is ok.
      Perhaps test it on a few things battery - car battery mains (carefully)
      whilst being careful Test the big cap again - is that steady
      • oddbodd
        • Mar 2013
        • 121
        It does test steady on some things. The big cap tested at a steady 336v today.
        • selldoor
          Slow Learner
          • 7870
          #64
          OK dont know if you have tried this
          re solder F301 if not already done so connect it all up except the main board.
          Have you got a 3v battery? or something that will give you 3vdc.
          or if you got a big resistor to drain the caps.
          Either connect the 3v neg to ground and pos to on/off then switch on and see if the backlights come on OR use the resistor and connect the 5v on the connector to the on/off on the connector using the resistor and switch on.
          If nothing else it shows that if it gets fixed the lamps work and its a bit
          encouraging to see.
          • oddbodd
            • Mar 2013
            • 121
            I've not got a suitable resistor to try that.
            I'll have a look, but I don't think I've got a 3v battery, either.
            You're right. It would be nice to see something working...
            • selldoor
              Slow Learner
              • 7870
              #66
              2 x 1.5 or even rechargeable 2x1.2 might do or a cr2016 cr2032 watch
              / cmos battery
              • oddbodd
                • Mar 2013
                • 121
                Yes, just found some CR2032s in the drawer. I'll have a go, tomorrow.
                • oddbodd
                  • Mar 2013
                  • 121
                  With F301 re-soldered, I've tested with the lamps with the 3v battery, and I get a little bit of flickering, but that's all.
                  • selldoor
                    Slow Learner
                    • 7870
                    #69
                    Hi - sorry- do you mean the lamps light well but flicker a bit or
                    lamps barely light at all
                    EDIT also v early on you said you replaced two caps
                    -did you use low esr ones? what make/series
                    EDIT2 also what was the original problem/symptom
                    if the set was yours what led up to that.
                    • oddbodd
                      • Mar 2013
                      • 121
                      The lamps don't really light up. I'm just getting a bit of white flickering now and again.
                      The caps that I removed were Rubycon ZLH 1000uf 10v. I've now got an ESR meter and have tested them, and they seem OK.
                      972uf/ESR.10
                      963uf/ESR.09
                      Replaced with SD C288H
                      They test at over 1000uf and ESR ~.06
                      No history, I'm afraid. The monitor was given to me and was DOA. I might be able to find out, though.
                      • selldoor
                        Slow Learner
                        • 7870
                        #71
                        I Have been reading back through- whilst one regulator was pointed out as being a problem I think the others need looking at.
                        Which one did you replace. ic???? Also there are only 3 so one of the other IC
                        is not a voltage regulator. Did you find any datasheets for them?
                        EDIt
                        Just sspotted it was ic1009 that was replaced
                        • oddbodd
                          • Mar 2013
                          • 121
                          I've not found any datasheets yet.
                          Details of the ICs are in post#42
                          3 on the top and 1 underneath.
                          • selldoor
                            Slow Learner
                            • 7870
                            #73
                            Yes I have been looking at that post
                            The one with 78 M0 9A KW 9A has me puzzled can you do a close up pic of it
                            The other two are 1117 s and with no other numbers are usually adjustable
                            with a minimum output of 1.25v so they are not right BUT they could be ok and something else affecting them. Can you do a closer pic of the board
                            perhaps in 4 shots. Its not looking good and I have been looking to see if
                            I could find another board but they are like hens teeth!!
                            • oddbodd
                              • Mar 2013
                              • 121
                              OK, will have a try in daylight, tomorrow, but my camera's not brilliant.
                              Edit. Message from previous owner...
                              "the monitor was working fine and suddenly one day it just stopped working and would not turn on at all."
                              Maybe it was struck by lightening!
                              • oddbodd
                                • Mar 2013
                                • 121
                                There's not a lot of daylight here [foggy], but here's some more pics...
                                I just noticed that there's also "J66" in the centre circle of IC 78M09A at IC1001.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #76
                                  Hmm - Im slipping!!
                                  The first one IS a 78M09A dont know how I didnt find it.
                                  Here is the data sheet
                                  http://www.alldatasheet.net/datashee.../L78M09AB.html
                                  Should be 9Volts !! Will have to think about that.
                                  • oddbodd
                                    • Mar 2013
                                    • 121
                                    Is this L78M05ABDT-TR a suitable replacement, do you think?
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #78
                                      Not sure why you would think that - are you looking at the datasheets
                                      the 09 in the 78M09A iindicates it is 9v fixed output
                                      the 05 in the L78M05ABDT-TR indicates it is 5v fixed output
                                      We dont of course know that it is faulty maybe just not getting voltage in.
                                      the 0 0 0 test result suggests that might be the case.
                                      • oddbodd
                                        • Mar 2013
                                        • 121
                                        I'm not sure why I thought that either!
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • Journey11
                                          Samsung TV won't turn on ... keeps cycling the power relay on & off
                                          by Journey11
                                          Hi All,
                                          First time posting here ... my name is Kevin but my friends call me Journey.
                                          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                          07-04-2024, 02:44 PM
