Dynex DX-32L150A11 Standby Blink
  • ohmmy
    • 182
    Re: Dynex DX-32L150A11 Standby Blink
    Well before seeing your reply I went ahead and connected the fan I used to load the psu for testing (12v .22A) in parallel with iPhone charger to supply the main board. Figured in parallel it'll cut down the current going to the board.
    Used some freeze spray and instantly noticed the 1.8 regulator warm up. Now my question is, could that be the fault or whatever it's powering? I'd imagine it'd be connected to the processor with a voltage that low at its output.
      I don't know what you mean by doing that... You'll probably find one power supply or another will take the whole load so it should be the same as with PSU? A 1.8V regulator could be the cause, you can remove it for a test (the set will not work right but it should have 5V steady.)
      • ohmmy
        • 182
        Doesn't current divide in a parallel circuit? That's why I connected the fan in to cut amps going to the main board. I could be wrong but it was quick thinking to limit current since I don't have proper resistor. Will remove regulator and see what happens.
          Doesn't work without resistors to divide current between equal or dissimilar voltage sources.
          • ohmmy
            • 182
            Isn't a fan a type of resistor (load)? Just trying to learn as a go. Thanks for helping along with this. Been helpful
              In a way but not really, also it would need to be in series with one of the power outputs to do such a job. (A computer fan has transistors in it to switch various motor windings, it switches rapidly between near zero and near infinite resistance.)
              • ohmmy
                • 182
                Wouldn't wired in series drop the voltage at the output?
                • ohmmy
                  • 182
                  Removed that regulator and now I have steady 5.20v at that rail and steady standby light. Power button doesn't do anything.
                  Anyway to test the regulator with ohmmeter? I have a bad feeling there's a short at its output somewhere and regulator is good.
                    What resistance, board powered down & unplugged from power board, do you get across 5V now?
                    • ohmmy
                      • 182
                      From 5v pin of main board to ground I get infinite resistance
                      • ohmmy
                        • 182
                        But from output pad of where the regulator would be to ground I get .2ohms
                          That sounds like you do have a short. The next thing to do would be to try tracing the short on 1.8V -- but unfortunately you WILL need something like a 1.5V power supply (maybe a 1.2V NiMH.) An ordinary alkaline cannot supply enough current.
                          • ohmmy
                            • 182
                            Damn. Know if I can find the service manual/schematic for this anywhere?
                              Amazingly, yes!
                              Detailed schematic of power board and main board.
                              • ohmmy
                                • 182
                                Awesome! Thanks
                                  Which reg is it that has the short? Nxxx?
                                  • ohmmy
                                    • 182
                                    N602
                                      That is a 3.3V reg (adj setup) on the schematic -- is that correct?
                                      Lift C661, see if short goes.
                                      • ohmmy
                                        • 182
                                        The part number on the regulator is 1117
                                        I've already tried lifting c661 and replaced c660 both made no difference
                                        what page of the manual is the mainboard schematic?
                                          Page 31 and others in that area. Just confirm that it is correct schematic, check a few component references to be sure, for example reg should have R603, R604 nearby.
                                          The short is on VCC3.3V if N602 and sch is correct, which is standby 3.3V rail. (Don't confuse with 3.3V_NORMAL)
                                          • Cookybaby
                                            Samsung UN60ES6500FXZA Power Supply Issue
                                            by Cookybaby
                                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                            Make: Samsung
                                            Model: UN60ES6500FXZA
                                            Power Supply P/N: BN44-00525A
                                            Symptoms: The TV was...
                                            08-20-2023, 12:26 PM
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • EazyBone
                                            Un50cu7000 2 blink oddity *partially solved
                                            by EazyBone
                                            I write this to maybe help another with this TV.
                                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                            03-18-2024, 10:24 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
