Samsung LN46A750R1FXZA Possible Bad Panel Or T-Con
  • jpruett79
    • 16
    Hey Everybody
    I'm looking for opinions on what could be wrong with this TV. From my limited experiences i believe that the most likely cause could be the panel or maybe the T-con board. I initially started to order a t-con to rule out the problem but the ones i have found have been priced higher than i want to pay without a second opinion. I would also like to rule out possible problems in the even i part the TV out. I would hate to sell a bad board to someone.
    I have looked over all of the boards and haven't found any swollen caps or burn marks. I have not checked voltages on any of the boards as i haven't been able to find a service manual but i will keep looking for one.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Samsung LN46A750R1FXZA Possible Bad Panel Or T-Con
    Have you opened the set yet? Being that the lines run the entire width of the panel, it's entirely possible that you have a bulging cap on the power supply. At any rate, I would guess something other than panel for the time being.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Do you have a photo of the panel with a source and picture playing? But I would probably best guess that this is a panel issue.
      • jpruett79
        • 16
        Guys thank you for the replies. This just got weird
        johnboy1313
        I have had the set open. I took that picture when i first got the tv. I did take it apart about 3 weeks ago and i took pictures of all the boards. I will go back and review those pictures. I did look at the caps and didnt see any swelled but i will look again.
        Glitcher
        Here is where it gets strange. So i could take a picture plugged the tv up back up and hooked my dvd player up to it. Initially i hooked it up hdmi. The picture came up briefly and then came up as mode not supported. So i changed to hdmi 2 and the same thing but as the picture went out i briefly got show for 2 seconds or so.
        Now the tv is hooked up playing with component cables I do have vertical lines in places they dont go all way to the bottom and do not show up on a black background. When i first cut the tv on i didnt have them and they do seem to get getting worse slowly but the tv has only been on about 10 min now
        I will have pictures up shortly. I think i took them too large and im having trouble uploading them. Will re-size then post.
        • jpruett79
          • 16
          Just a quick update. I haven't had time to take the tv apart again but i did go over my pictures closely and didnt see any swollen caps. But hopefully tomorrow i will get it back apart and look closer once one. I am starting to sway my thinking away from the panel to something signal related. It is still bothering me that the hdmi ports didnt work.
            I have seen those lines (with working video) with a bad panel.
            • jpruett79
              • 16
              First of all Tom66 Thank you for your input. It is greatly appreciated. I have learned a lot from your post on this site. I have some more information. Do you still think it is a bad panel? I only ask not to second guess you but because i intend to part the tv out and don't want to risk selling a part i think is probably bad.
              Secondly. I realize its been a couple months since i have been able to update this thread but i have had some more time to work on this set and have seen some strange behavior. I would like to share this information in case someone else ever runs into the same problem.
              I hooked the tv back up today to take some pictures before parting out the tv. I wanted to test all the inputs to the mainboard before selling it as i take my reputation seriously and don't want to sell a part that i genuinely think is bad or has a high probability of being bad.
              The first thing i hooked up was the coax signal and didnt have any lines at all. The picture looked great so that made me really scratch my head. Later some lines did appear after i had the tv on about 30 min.
              The coax signal did always work.
              The hdmi signals did work at first. At least input one and input 2 did. When i tried to hook up hdmi 3 the tv went to snow but 2 seconds and then i got the message mode not supported. When i went back to hdmi 1 and 2 i still got the mode not supported. After about 15 min i hooked hdmi 2 back up and it flashed between snow and the picture.
              The component signals did always work but it did develop lines after about 3 min. The thing that seemed strange about the lines was they only appeared connected to text or a specific object on the screen. after watching for a few min i noticed that the lines followed the object they were connected to.
              for example at one point one of the characters was carrying something and there were vertical lines connected to his hair as he walked across the screen the lines followed his head perfectly.
              At one point i cut the tv off and then turned it right back on. When i did that i got a black screen with a bunch of vertical lines.
              At one point i also noticed some horizontal lines but they didnt seem consisted and could have been a problem with the signal.
              I am attaching a few of the photos i took to show the various states of the tv. If you think any more of a particular state would help i can add more.
              Is it likely that the problem could be a video processor problem. Given my limited experience the only times i have seen these vertical lines were with a tcon and the rest i had decided was a bad panel but all of those were much more consistent problems.
                It could be a tab bonding fault. I expect the main, t-con and power boards are just fine.
                • jpruett79
                  • 16
                  Could that cause the occasional "mode not supported" error when trying to use the HDMI connections. I guess that is the one that is throwing me off the most. Seems like its the TVs way of saying i don't know what to do with this signal.
                    Check your HDMI cable is good, as I had this issue with an intermittent HDMI cable.
                    • jpruett79
                      • 16
                      I have tried two different cables but i will try a third. The second one i tried was a new but untested cable.
                      • jpruett79
                        • 16
                        I did try a third cable. One i know that is good. I still got the mode not supported error. Im working now on taking the tv back apart. Im going to look over things one last time to see if i see anything.
                        • digitsync
                          • Jun 2011
                          Your TV does not support all video resolutions from PC video card,
                          adjust your video mod according to the Samsung. Also if you try
                          to press Chanel keys while in PC input mode then you'll get the
                          warning message.
                          • jpruett79
                            • 16
                            I realize this is an old thread but i wanted to update it with some new information in case someone runs into a similar problem.
                            I did scrap the tv and sold the parts on ebay. I did plainly list them for parts or repair at a deeply reduced price since i could not confirm the diagnosis. Based solely on the response the buyer left me in feedback the board was bad. I ask him for more info but he would not respond.
                            While this is not a concrete answer i hope it will help someone in the future.
                            Thanks to all of you that helped me with this one.
                              09-07-2024, 05:50 AM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • NWArkGuy
                              Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                              by NWArkGuy
                              Well, I will be the first to admit that I screwed up...
                              In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                              I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                              I have 2 that I have found and have in my possession. ...
                              10-12-2023, 10:13 PM
                            • KYBOSH
                              Samsung UN50TU8000 - Dead Panel Forensic Questions
                              by KYBOSH
                              I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                              When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                              When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                              Later I checked for shorts on the panel PCB boards but could not find anything.
                              When I took a look with the FLIR i noticed the 2 resistors...
                              08-10-2024, 08:39 AM
