samsung LN-T4042H back light bypass?
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    The TV failed to make it passed startup.
    Did some measuring and found one bad transformer on the inverter board.
    Now I watched the video explaining how to bypass a transformer but that video explains it on a transformer with a dual coil primairy side...
    This one the primairy side the 4 pins are connected in pairs,left two on one pad,right side legs on one pad...
    I understand the safety circuit as to where if the current gets to high,the diode breaks open and tells the TV there's a fault.
    I did an attempt to bypass that transformer by soldering a 470ohm resistor in place of the broken transformer with no luck.
    Anyone know how to bypass this properly???
    I will order a transformer soon,just want to bypass for now and test the TV for awhile....
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    09-07-2024, 05:50 AM
  • unimatrix93
    Replacement transformer for Samsung fridge
    by unimatrix93
    Dear forum
    My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
    No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
    The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
    My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
    07-14-2025, 02:16 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
