zenith z50px2d no picture
  • Ovalking
    • Jul 2013
    • 57
    • Usa
    Hello I have a zenith z50px2d no picture I've been reading
    Every one seems to thinks its the tcon board is there any thing
    That can be change in board to fix it ? Thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: zenith z50px2d no picture
    First of all that's a plasma not am lcd so there is no tcon board in that set. Its a plasma made by lg. You need to be looking at t esting the ysus and zsus boards. More specifically the ipm modules under the big heat syncs to start.
    • Ovalking
      • Jul 2013
      • 57
      • Usa
      Thanks ill look what should I look for ?
      • freakaftr8
        • Oct 2012
        • 3743
        Well firstyou need to see if your voltages are up or not in the power supply. Does the tv stay on now? You need a voltmeter and set it to dc. Black lead or ground or chassis of tv. Red lead test vs and va
        • colorless
          • Jul 2013
          • 25
          • canada
          also can check the buffer boards by removing the upper or lower one at a time.
          • Ovalking
            • Jul 2013
            • 57
            • Usa
            Vs I'm getting 192.1 on all 3 I'm getting 60.45 on va
            • Fly_Among_Stars
              VIZIO E70-E3 Half picture with half TCON
              by Fly_Among_Stars
              I have a VIZIO E70-E3.
              Symptoms: Black screen, no picture, but LED backlights are working.
              I probed the power board and voltages are as listed on the board.
              Main board appears fine, too.
              I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
              There are two separate ribbon cables feeding the LCD.
              If both are connected, the screen is black.
              If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
              04-24-2023, 08:20 PM
            • iglitare
              Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
              by iglitare
              i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
              Backlight seems to work, Sound (Setup menu after reset) works.
              If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
              Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
              With my small knowledge i would think at least the cables are good.
              Can this happen because of a bad tcon board?
              Or is it always a bad/shorted...
              09-04-2025, 07:13 AM
            • shelby5041
              Samsung LCD TV no picture backlight on no 12v at tcon
              by shelby5041
              hi
              i have a samsung lcd tv
              it powers on with sound and backlight but no picture
              all voltages from PS are good 12v 3.3v and 5v
              whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
              i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
              no 12v at the tcon fuse
              i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
              the odds of having 2...
              10-08-2021, 08:21 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
