Samsung PN50A510 P3FXZA Plasma Cycling On/Off
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    #141
    Re: Samsung PN50A510 P3FXZA Plasma Cycling On/Off
    Question on reflow....do u just put entire main board in over at 375 for 20 min?
    What about the pastic components on the board?
    • shelby5041
      • Feb 2009
      • 1504
      #142
      Disregard reflow question i figured it out but it didnt fix issue...will try replacing c102
        20 minutes? No.
        That's called "cooking" the board, not reflowing it!
        You also need flux on the component you want to reflow.
        5 minutes, 220C maximum temperature, and ramp oven up slowly, then allow board to cool down in oven slowly.
        • shelby5041
          • Feb 2009
          • 1504
          #144
          i did 9min at 385f .....it didnt fix.....
          • shelby5041
            • Feb 2009
            • 1504
            #145
            i left in oven to cool down 45min
            • shelby5041
              • Feb 2009
              • 1504
              #146
              thanks for ur good advice tom....forgot aboyt flux.....should i try again with flux ?
              im thinking maybe its the infamous bad cap issue c102 like kevin and many many others had
              • shelby5041
                • Feb 2009
                • 1504
                #147
                Hi..i know this thread started a few years ago...but i have samecsymptoms of tv cycling on and off indefinitely....all voltages coming from ps good....i isolated to main issue per experts in here telling me to jumper pins 3-4 on logic and disconnect lvds from logic to main
                I did this and tv still cycles on and off but during the on cycle i now get a crisp bright test pattern display on the screen....due tonthis im being told its probably a main board issue as my research was directing me towards
                However....i have done all the fixes per this thread and tv still cycles on and off....
                I refllowed main board 385f for 9 min in oven
                I replaced c102
                Afny input would be appreciated......if main board was affordable like under $50 i would replace it but as we all know this main hard to find and over $100.....this tv isnt worth repairing at that cost.
                • shelby5041
                  • Feb 2009
                  • 1504
                  #148
                  There is an ic101 in the repair kit for this main board......but i haventvseen anyone needing to replace it in here to fix their issue...
                  • shelby5041
                    • Feb 2009
                    • 1504
                    #149
                    Fyi
                    C131 is located on top side board not bottom as c102 is
                    They are both 47uf 10v caps
                    Ic1203 is on top side board
                    Ic101 is on bottom side board next to c102
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #150
                      if the repair kit is cheap enough i would change both the ic s and both capacitors that way you have ruled them out all because no one else has seemed too of changed the ics does not mean they have not failed on your set you may just be the unlucky one
                      • shelby5041
                        • Feb 2009
                        • 1504
                        #151
                        thanks vince
                        ill replace c131 (1.00 arrow.com) and ic101 $1.00 ebay)
                        • shelby5041
                          • Feb 2009
                          • 1504
                          #152
                          fyi ic1203 i belive is for audio issue only....which i dont have
                          • shelby5041
                            • Feb 2009
                            • 1504
                            #153
                            and im using low esr elrctro alum cap i just mount the through hole style legs to thr surf mount pads
                            for testing purposes should work fine...
                            • shelby5041
                              • Feb 2009
                              • 1504
                              #154
                              Hi vinceroni....i replaced both caps c102 and c131...tv still cycles on and off
                              Im waiting for ic101 shipment
                              • shelby5041
                                • Feb 2009
                                • 1504
                                #155
                                Aaron said he has never had to replace the ic...he said c102 and c131 should fix
                                in my case thats not true
                                • E--Man
                                  • Oct 2017
                                  • 27
                                  Can I use a 47uF Electrolytic Capacitor I have in hand with the same or higher voltage?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #157
                                    as long as you get the polarity rite when you fit the capacitor you should be fine
                                    • E--Man
                                      • Oct 2017
                                      • 27
                                      Many thanks for the quick reply!
                                        BTW, the white bar on that Tantalum cap = Positive.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #160
                                          Thanks budm i was trying to find that information too add to my reply
                                            09-07-2024, 05:50 AM
                                          • high-tech
                                            Samsung UN55F7050AFXZA ver. TD01 power cycling
                                            by high-tech
                                            Hello everybody, I could use some help on this one... It's got me guessing...
                                            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                            9. ground (PWM2) 10. 0.9 volts cycling...
                                            09-15-2020, 03:39 PM
                                          • bcstedt
                                            Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                            by bcstedt
                                            Just starting to crack into this one and wanted to get the ball rolling.
                                            At power on (plug in), power light on, relays click, repeat (sometimes)
                                            After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                            Removed Y-Main for inspection and testing
                                            This pic from:
                                            PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                            12-15-2023, 10:30 AM
                                            09-06-2024, 11:40 PM
