Re: White Screen on Emerson LC320EMXF 32" 720p HD LCD Television
There's no t-con on this (built into panel) so possible causes
loose ribbon as mentioned above
bad LCD panel voltages (the PSU board generates the various voltages for the panel on these crap Funai sets)
blown fuse on t-con panel board
bad LCD panel
bad LCD panel
I was looking for loose ribbon first thing I opened cover. Can't find one.
Bad LCD should have sound.
That make either blown fuse on t-con panel (where is fuse?) or bad LCD panel voltages.
Tom, do you think change PSU board ($45 on ebay) can fix the problem?
It might fix the issue, but I'd like to figure out what's causing the exact fault first. Cannot find a schematic for the LC320EMXF though.
I found a working PSU board. It still gives white screen after exchanged the board.
