possible purchase maxx tv
  • freakaftr8
    • Oct 2012
    • 3743
    Re: possible purchase maxx tv
    Oh and it is most likely a 720p as I have never yet in my past experience seen a 480i 50 inch panel...
    I have seen some tvs just randomly blow a 5v or 15v fuse, mostly due to a power surge of some type, usually when the set was on. Like an air compressor or a large load on the circuit the tv was connected to.
      LG had one really early one in 2001 but that's the only one I know of. Given the number of buffer ICs (12) it's probably a 768 line panel (64 lines per IC.)
      • freakaftr8
        • Oct 2012
        • 3743
        Oddly, I would be intrigued to see one in person..
          LG's plasma module line up begins with (2001) PDP42SD1, (2002) 42SD2, (2003/2004) 42SD3, (2005) 42V5/42X2, (2006) 42V6/42X3, (2007) 42V7/42X4A. They also may have had a PDP50SD3 (480p) but there's only sparse info suggesting it was a very rare panel module. I saw a few boards with that printed on it but can't find a datasheet. PDP50X2 was available in 2005.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Originally posted by Caleb
            Not sure what caused it to pop in the first place but I will test it out and hopefully it stays working. Its built like a tank and weighs almost as much.
            Is that picture Vermont? (During the August 28, 2011 flooding)
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              @freakafter8 it was one of the cleanest tvs Ive opened yet, no dust or evidence of spillage.
              @rjarrrpcgp that bridge is located in Yachats, Oregon, although we have pictures of some in New Hampshire and Vermont right after that flood.
              Liberating magic smoke one part at a time
              • Rictech
                Panasonic SA-MAX770PU SMPSU board fault....
                by Rictech
                Hello everyone. 😀
                As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                There are no devices that have exploded or otherwise show signs...
                08-26-2024, 01:05 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
                ESR meter came to the rescue again today with a PLC I/O card fault
                I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                12-18-2023, 08:17 PM
              • Agent24
                What kind of fault causes this image error?
                by Agent24
                I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
                The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
                What's the most likely cause of this problem, does anyone know?...
                09-22-2025, 11:42 PM
              • cazi1001
                Strange fault on Lenovo ThinkPad E14 Gen. 2
                by cazi1001
                I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                03-24-2024, 04:16 AM
