Screen image of vertical yellow that aligns with right end of C1 board. Have reseated ribbons but no change. Any suggestions?
Panasonic TH 50PZ80U Transparent Vertical Bar-image
Re: Panasonic TH 50PZ80U Transparent Vertical Bar-image
I had this problem with the same tv. Turned out to be a panel issue.Did I leave the soldering iron on? -
When the TH 50PZ80U TV warms up, a 3 inch transparent yellowish vertical bar appears in a fixed position from top to bottom on the right side of the screen. The bar overlays any video input including the TV’s menus. It first appeared with images that have white backgrounds. It now appears with any background. It may disappear for a while if I tap on the chassis. I have re-seated some of the ribbon cables with no effect on the bar. Has anyone else experienced this? The yellow bar appears over the C1 board. If the ribbon cable that aligns with the bar is removed, the bar is filled with static.Any suggestions on how to diagnose and solve this problem?Comment
You could try some freeze spray on that bottom buffer to see if is heat related. You should be able to find a bottom buffer pretty cheap as they seem to be a rare failure. Though it does sound like it may be a panel problem.Last edited by Caleb; 10-03-2013, 10:54 PM.Liberating magic smoke one part at a timeComment
by JDCIssue: Panasonic TH-50PZ80U works fine but has no HDMI output.
Easy solution: replace main board.
Advanced solution: replace HDMI chip on main board.
Unless you've got the time, tools and the hands of a surgeon, skip the advanced solution. For you beginners out there reading this, you would need to use a combination of a heat gun, flux, solder, and probably a microscope to succeed. If there is someplace you can send the board in for repair, you can go for that. From what I've read elsewhere, I don't think this TV will even do 720p.
If none... -
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
...1 Photo11-20-2024, 08:52 PM -
by mopensteinI'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped... -
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... - Loading...
