philips tv 3000 model 42pfl3605h/12
  • nickovic111
    • Sep 2013
    • 15
    • croatia
    Hi
    i have philips tv 3000 model 42pfl3605h/12
    when i turn it on led are not blinking and i can see the backghlight turn on and i can hear sound but i got no picture.also i can hear the reley switching in power suply
    i open it and there is no visible damage on power supply (bad capacitors) and no damage on SSB.
    but when i disconected the right flat cable of the screen the picture showes up only on left side of the screen but on the right side is white screen...
    for now i only have picture of ssb
    help would be nice
    thnx
    Re: philips tv 3000 model 42pfl3605h/12
    It sounds like from this the LCD panel is defective.
    This set is not made by Philips but instead TVE (Top Victory Electronics China), as a rebadge for Philips as they've decided it's cheaper to deceive customers into thinking they're getting a good product than actually making one. Probably due to the crappy LCD panel (Chimei? Chungwha?) this has occurred.
    You can try looking closely at the t-con for example testing the fuse on it.
    • nickovic111
      • Sep 2013
      • 15
      • croatia
      it could be it so then there is no way to cheap repair...
      i tried to look for fuses but they are not numbered or explained like F01... or F02...
      so i searched trough the tcon board but only to find some i believe fuse "THX..." something like that and i tested it it is ok.
      if you know the names on the fuses on this kind of board can you tell me?
      i think there are no fuses there
      thnx for quick reply
        It would help if you provided pictures of the T-con so fuses can be highlighted.
        • nickovic111
          • Sep 2013
          • 15
          • croatia
          i will take detailed pictures later ( on my time in about 7-8 hours) so i will post them here and please dont forget me and check my images
            In some cases your post may get missed, if that happens do not feel bad about "bumping" it - posting a reply - after a day or so.
            • nickovic111
              • Sep 2013
              • 15
              • croatia
              ok
              • nickovic111
                • Sep 2013
                • 15
                • croatia
                up
                here are new pictures of ssb
                i also turn on tv and checked voltages going from PSU to SSb and they are ok
                so we are looking for some fuse or some idea or is my screen dead for real
                  Can you provide one large image of the layout of the circuit boards in this set? I am trying to see if this set has a T-con board.
                  • nickovic111
                    • Sep 2013
                    • 15
                    • croatia
                    these two boards are only boards on tv set i believe because the flat cables are going straight underneath the tv to connect screen i belive
                    isnt t-con underneath this aluminium cooler ( i removed the protecting top)
                    i found this image on web
                    it is exactly like mine tv
                    on this link http://monitor.espec.ws/section31/topic200017.html
                    if you check this link my tv is what Borek posted
                    i translate it just now in English so i can start reading because "Borek "wrote some links about fault threads in that forum about my tv...
                      The T-con controller IC is probably the large multi pin chip near the ribbon cables.
                      The processor under the heatsink is the main video processor/scaler.
                      See image - please give me the part #s of the two highlighted chips.
                      • nickovic111
                        • Sep 2013
                        • 15
                        • croatia
                        as soon as possible i will get those numbers
                        i m really greatfull to you for trying to help me
                        • nickovic111
                          • Sep 2013
                          • 15
                          • croatia
                          here are pictures of those 2 chips
                          sorry for being late
                          bump
                            OK first IC is custom LG Display T-CON controller.
                            Second IC is the voltage generator. Let's look at that first, because a datasheet is available.
                            https://cdn.badcaps-static.com/pdfs/...f8b27c5dc1.pdf
                            See picture for checks.
                            Be VERY careful not to let the probe slip... if in doubt solder a wire to the appropriate pin and measure off that.
                            • nickovic111
                              • Sep 2013
                              • 15
                              • croatia
                              wow thanks a lot i will do this measurements in couple days and info you
                              thanks!!!!!!!!!
                              • angel-boy
                                • 550
                                • Romania
                                i have a tv with a problem
                                after plug in power, no light , the owner say that after 2 days the tv starts and working, but no sound , only audio output
                                i mesure the power bord, is only 5v, not 12 or 24v
                                  Same make and model of this OP?
                                  If it is, then you should up load good clear pictures of YOUR TV that show the whole back side of the TV, and pictures of board especially around the connectors so we see the label for each pin of the connectors.
                                  We need to find out if you do have PS-ON signal from the Main board to turn on the rest of the power supply or not.
                                    HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                    This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-06-2024, 05:27 AM
                                    HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                    This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                    HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                    This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    Lenovo 3000 Series Schematic
                                    Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                    3000 C100 laptop with Braille keyboard
                                    Lenovo 3000 C
                                    C100, C200 - 15-inch XGA screen
                                    Lenovo 3000 N
                                    N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                    N500 - 15.4 inch screen.
                                    Lenovo 3000 V
                                    V100, V200 - 12.1-inch WXGA models
                                    Lenovo 3000 G
                                    G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                    10-04-2024, 06:05 AM
