sharp aquos LC-80LE632U led tv lamp error
  • freakaftr8
    • Oct 2012
    • 3743
    Re: sharp aquos LC-80LE632U led tv lamp error
    Your TV is a completely different ballgame the 80 inch uses LEDs that are backlit your TV uses edge lit so if you have one LED go out in your string you're going to have an array of LEDs in that same area go out causing a black patch.
    • stereojohn
      • Mar 2016
      • 11
      • canada
      #82
      Hi and thanks that testing of codes on power-up got my tv on with leds lasting only 2 sec as usual but the rest works got sound and picture just no backlight and a constant inverted v light thanks aggain
      • Dale Mech
        • Jun 2016
        Originally posted by freakaftr8
        The mainboard must generate only one signal the power supply gives it if backlight is in error. All other errors are generated from mainboard. Off the error pin if it goes high it generates a power supply fault codetwo quick flashes 5 slow flashes. The error pin stays low all tje time. Without or with the backlights working I believe the mainboard monitors this by the balancing of the data and clock signals generated by the backlight driver. The pins are called adl and acl
        I have sharp LC-80LE632U tv I have no picture at all. was watching and the screen went blank. I tried a factory reset and flash light to see if the screen was on but it wasn't. I not sure if the back light is bad. The service manuel they show the componet positions and interconnections. The light is white and steady flashing when you turn the power on with the remote it goes out like power came on but the screen is still blank. Is there anything else I can do before I open this beast up. I would much appreciate any type of input.
        Thank You.
        • Dale Mech
          • Jun 2016
          Dont know where to start tv won't power up at all. Tried reset with the input and volume down holding and pluged tv back in. No luck, anyone know anything about where to start to test to find the problem. I hate to open this beast up unless I really have to. The power light is white and flashing steady. When you power up on the remote it stays on steady. The screen is still blank, anyone have any idea's. The service manuel doen't tell you anything it just tells you how to take it apart and the layout of all the boards that interface with each other.
          • jjanssen7
            • Nov 2012
            • 252
            freakaftr8, I don't think you posted how you repaired your TV in the end?
            • sacosta80
              • Aug 2016
              • 8
              • united states
              #86
              Please help!!
              • sacosta80
                • Aug 2016
                • 8
                • united states
                #87
                Im hoping I can fix this, if anyone can help
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #88
                  Hello Sacosta
                  This is a different model so you would be better off starting a new thread.
                  • sacosta80
                    • Aug 2016
                    • 8
                    • united states
                    #89
                    yeah, I apologize. I had verified my email and all but still wouldn't let me start a new thread till today. Thank You!
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      Please help!!
                      Have you hooked up different inputs and it happens on any of those inputs?
                      Permanently Retired Systems:
                      Kooky and Kool Systems
                      sigpic
                      • Inverted
                        • Dec 2015
                        • 26
                        service manual shows input vol- at the same time in plug in TV but when I try to do that I get the one flash two flash sequence I can't get it into service mode. the only way to get this set to turn on is to hold down the volume down channel up button at the same time but that wont allow going to the service menu
                        What was the fix for this? I am having this exact issue and the fix was never posted. I am having these EXACT same issues with a Sharp LC-70LE374U. If I hold the vol+ and channel- when I start the tv, the tv works great.
                        • Yanleb
                          Sharp LC-60LE810UN Lamp Error
                          by Yanleb
                          I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                          I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                          Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                          I've tried all the key...
                          08-24-2021, 11:48 PM
                        • Sus256
                          HISENSE 65E7KQ PRO - no boot
                          by Sus256
                          Hi all!
                          HISENSE 65E7KQ PRO
                          RSAG7.820.13512 - chassis
                          MT9618BAATAB - cpu
                          RSAG7.820.12059 - power
                          HD650Y3U77 - panel
                          KLM8G1GETF - emmc
                          The TV does not turn on, the standby indicator is on. All voltages are present.
                          Emms is dead. Not readable, not detected.
                          Replaced emmc.
                          But with another dump there is no launch
                          Terminal log
                          UART
                          AC_ON
                          RPMB key is not yet programmed
                          HASH1_VERSION=0x00000000 64bit
                          E-B
                          FDE enabled
                          layout pattern onebin by SAR7,0...
                          06-01-2025, 02:11 AM
                        • michalk3777@gmail.com
                          Sharp Hisense - LC-65N7004U Error codes
                          by michalk3777@gmail.com
                          Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                          Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                          Regards,...
                          12-15-2024, 09:20 PM
                        • scubacamper
                          Sharp Aquos LC-70C6400U Half Screen Dark
                          by scubacamper
                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                          05-03-2025, 12:19 PM
                        • Eric D.
                          Sharp LC-60LE810UN Lamp error
                          by Eric D.
                          Hello everyone!
                          I just acquired a Sharp Aquos for free.
                          When I plug it in, it will try to power on, but it fails.
                          The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
                          I did a bit of research and did what I found could be the possible issues;
                          I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
                          I also tested the leads going into the psu board from the wall connector; I get 120V.
                          I disconnected...
                          01-18-2025, 05:14 PM
