sharp aquos LC-80LE632U led tv lamp error
    Re: sharp aquos LC-80LE632U led tv lamp error
    The LEDs will be driven by a constant current circuit. The constant current circuit will increase the voltage the LEDs are driven with until the current matches. If an LED is open the voltage will hit an over-voltage threshold and the PSU will shut down.
    • freakaftr8
      • Oct 2012
      • 3743
      Good to know. Looks like ill be pulling the panel apart tonight.
      • capkid
        • Oct 2010
        • 1339
        "hey all well I picked up this 80 inch Sharp Aquos" - LOL. Someone must be made of money to just give up on an 80-inch TV. I'm off to do a Craigslist search.
        LG Plasma Mal-Discharge Correction Service
        • freakaftr8
          • Oct 2012
          • 3743
          Well I pulled the panel and powered up the tv. Every LED is lighting up. I cannot get a reading from each strip. Do I have to measure every diode independently? They all light up the same lumens as well.It is backlit.
          • freakaftr8
            • Oct 2012
            • 3743
            here it is. All leds lit. Quick snapshot before it cycled off to error blinks.
              Boy, what did you use to lift 80" LCD panel?
              • freakaftr8
                • Oct 2012
                • 3743
                My naugin. Lol. Just taped the carriers to the screen and lifted it out. It was tricky!
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Well screens back in. Obviously the led array is not the problem. Now im looking into power supply. Especially the led controller.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Led controller IR2E67M sharp manufactured. What pin does led monitoring short and open led monitoring? Thinking of "temporarily" disabling it.
                    it's obviously a false code all the LED's are working perfectly
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Well in other sharp tv's like the 32 inch there is a chip cap C7558 that you can bridge to get the ic to not time out and throw an error code. I wonder if that applies to this design as well? I am looking for C7558 and cannot find it.
                        Yeah there probably will be a timer cap.
                        Can you post a picture of the LED controller?
                        Also, check LAMP ERROR signal, if present, from PSU to main - you may be able to jumper this.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Got a pic, ill upload it. What would I short lamp error signal to on the wire loom to the mainboard. Ground possibly?
                          Pin22 on cable is just stated error. Thats it is this lamp error possibly?
                            Yeah through a 100 ohm resistor to limit current though.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              led controller/ driver
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Btw I used a 150 ohm from error pin to ground. Same issue.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Here's the whole back side of the board
                                    Ugh, well it's probably a semi custom Sharp IC without a datasheet.
                                    Check LAMP ERROR what does it do? Go high, low, what? After this, BL ON/OFF (or similar) changes too?
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Originally posted by freakaftr8
                                      What happens if u put in your old board?
                                      When I put the old board back in, it worked fine but no HDMI's. I wound up pulling the EEPROM from the old board and putting in on the new board. Now everything works but the WI-FI, which did work on the old board. I haven't figured that one out yet. Ethernet does work however.
                                        I hate EEPROM problems!
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          Heres the pinout.
                                          • Yanleb
                                            Sharp LC-60LE810UN Lamp Error
                                            by Yanleb
                                            I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                            I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                            Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                            I've tried all the key...
                                            08-24-2021, 11:48 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • michalk3777@gmail.com
                                            Sharp Hisense - LC-65N7004U Error codes
                                            by michalk3777@gmail.com
                                            Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                                            Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                                            Regards,...
                                            12-15-2024, 09:20 PM
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • Eric D.
                                            Sharp LC-60LE810UN Lamp error
                                            by Eric D.
                                            Hello everyone!
                                            I just acquired a Sharp Aquos for free.
                                            When I plug it in, it will try to power on, but it fails.
                                            The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
                                            I did a bit of research and did what I found could be the possible issues;
                                            I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
                                            I also tested the leads going into the psu board from the wall connector; I get 120V.
                                            I disconnected...
                                            01-18-2025, 05:14 PM
