17PW25-4 found in 26" Vestel "Digihome" fixed
    Another free TV from a friend. Fault blown fuse, no power -- same as 42" Vestel I am working on.
    Found one shorted diode plus blown FET and associated driver components.
    The bank of 8x3A through hole diodes were for the 24V. These diodes are all in parallel, a very bad idea. The diodes are not thermally matched, so if one gets hotter than the other, its forward voltage will drop, causing it to take more current, causing it to get hotter, causing it to take more current... This cycle is destructive to the diode. The poorly designed current limiting of the power supply means this damages the FET and other components. Only one was failed, but I elected to replace all 8.
    The power supply is rather bizarre. It does not have a large 400V capacitor. Instead, it uses a transition-mode PFC controller in a flyback configuration. The main 24V output capacitors (3x3300uF) are the bulk for the PFC, plus the 12V. The measured output ripple is in excess of 1Vp-p.
    This PSU is also used in the rebadge Toshiba 32BV501/502/701/702 sets. It is an unworthy pile of rubbish.
  • Ralph Green
    • Feb 2013
    • 66
    Re: 17PW25-4 found in 26" Vestel "Digihome" fixed
    Hi Tom66. I got Toshiba 32BV501B with 17PW25-4. TV is just blinking orange diode so I think is PSU. Checked Q935 and is fine (not shorted). What else can I check to repair this TV?
    Thank you.
    • selldoor
      Slow Learner
      • 7870
      As Tom said it is rather an unusual power supply. Can you post good clear pictures of your board and also of the main board.
      Perhaps next test with it all connected up would be to work along that big connector to the main board and list the voltages. I dont suppose that the expected results are listed on the board - front or back of either board?
      If you struggle to get probes to metal with the connector in place then get
      a sewing needle and insert alongside the wire and test to that.
      With the power off you could test all those diodes
      • vinceroger69
        • Mar 2012
        • 6714
        wrong post sorry
          Blinking orange is PSU or main, if you have no voltages from PSU then it is PSU, otherwise it is the main board.
          • vinceroger69
            • Mar 2012
            • 6714
            tom have you a scheme for this psu i have one here but not sure if the output voltages are ok.
            • Ralph Green
              • Feb 2013
              • 66
              It's not easy to check voltage because outputs are not marked on pcb. I think I will need schematic for this PSU. Attached pictures. There is one diode D927 missing. I've found this one faulty, it's not shorted just not giving anything while testing.
              • vinceroger69
                • Mar 2012
                • 6714
                you can get 2 free downloads a day i have used my limit today.
                  SCH:
                  • Ralph Green
                    • Feb 2013
                    • 66
                    Thank you tom66 for schematic. Weird thing just happened. I put PSU back to TV and is working now Was it diode I've removed? Now there is only 2 instead of 3. Just ordered diodes on ebay so I will put 3rd diode back.
                      That could be, if that diode was shorted. You are very lucky it did not blow the FET. Maybe that only happens on 24V. I've found tons of Vestel PSUs with bad diodes... crazy how common this failure is.
                      • Ralph Green
                        • Feb 2013
                        • 66
                        That diode wasn't shorted. Just won't give any reading from multimeter like others did.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          was it open circuit did you have a reading at all?
                          • Ralph Green
                            • Feb 2013
                            • 66
                            Sorry guys. This one was shorted.
                            • mesersmith
                              • 35
                              • România
                              Originally posted by tom66
                              SCH:
                              Hi, Tom!
                              Can you tell me with what software you created your web database?
                                Originally posted by mesersmith
                                Hi, Tom!
                                Custom PHP scripts, about a day's work to put together. Based internally on text databases, would you believe it. I didn't want to use MySQL because I had just finished a huge MySQL project and was getting a bit bored of it.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  Tom a bit of a old thread but can you remember how to force on the psu by itself as we want to check all the output voltages on one of these psu s in another thread thanks.
                                  • caspian
                                    What Zener Diodes on a Linear Power Supply
                                    by caspian
                                    Dear members,
                                    I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                    In addition, I discovered that its zener diodes are defective.
                                    I can replace the burned transistors.
                                    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                    Therefore, I cannot replace the zener diodes.
                                    I do not want to test the zener diodes in a test circuit to discover their model or value.
                                    no schematics are available...
                                    05-26-2025, 12:38 PM
                                  • Jaime Morillo
                                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                    by Jaime Morillo
                                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                    The TV was stuck on the logo and I couldn't access the update menu.
                                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                    The image result was good, but the image is inverted.
                                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                    08-18-2025, 11:38 AM
                                  • tonydix
                                    Digihome Vestel 500UNDC TV loses picture after a few seconds
                                    by tonydix
                                    Vestel 500UNDC using a vestel 17PS20 power board. Backlights come on and picture shows for a few seconds and then goes dark. Sound is fine. Is this a problem with the led strips or the backlight driver ? Many thanks
                                    11-15-2021, 05:37 AM
                                  • France_53
                                    Vestel tv, how to flip the image?
                                    by France_53
                                    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                    05-12-2024, 05:22 AM
                                  • FlailingEngineer
                                    Help with Bush Tv (Vestel 17mb95m Mainboard)
                                    by FlailingEngineer
                                    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                    05-31-2023, 06:52 AM
