60ls5700 no picture only audio and backlight
  • weshig
    • Jan 2015
    • usa
    Re: 60ls5700 no picture only audio and backlight
    I have the exact same problem I have changed out the T-con board and checked the above mentioned fuse, fuse seems good, I get backlight and audio but no video.
    model is a 60LS5700
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • Mgiffune
      by Mgiffune
      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
      I ordered a supposedly β€˜new' Tcon board this time, and
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
