Toshiba 32A3000P inverter problem!
  • nathaniel
    • 35
    • israel
    hello everyone
    got this LCD recently from a friend , the TV has sound but no pic and no backlight.
    i dissasmbled the screen and found that there are two blown caps on the inverter board (6632L-0420A )and also it seems like the transformers has been replaced .
    what is your expeirience would replacing the caps solve the problem or a kit i've seen on Ebay :
    http://www.ebay.com/itm/271185516140...9#ht_762wt_932
    or the complete borad should be replaced.
    thank you very much for your time...
    Re: Toshiba 32A3000P inverter problem!
    Some info (not sure how true this is):
    • nathaniel
      • 35
      • israel
      tnx for the quick reply.
      just wondering is it a fix or just prevanting the problem to occur on a working set. (since the caps on mine are already blown? )
        Blown caps will definitely cause flickering or no backlight. Replace them with Panasonic FC, FM or FR, available from Digi-Key, Farnell/Element14 or eBay (make sure to avoid fakes!) The capacitors in the eBay auction are cheap replacements and will likely fail quickly.
        • nathaniel
          • 35
          • israel
          o.k tnx i'll try to replace the caps first.
          digi-key are too expensive on shipping (44$) ???
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            you can select small order usps for about 4$
            edit never mind just noticed you are not in the states
            Liberating magic smoke one part at a time
            • nathaniel
              • 35
              • israel
              UPDATE: hi guys , i got the two caps replaced with new ones - but still no backlight
              could it be one of the light tubes that causes no light (as in pc monitors)?
              what should i do next at your opinion ?
              TNX
                Do you have stable 24V going to the inverters?
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  I would also check all the MOSFETS on the inverter boards to see if they are shorted.
                  • nathaniel
                    • 35
                    • israel
                    thanks for the quick reply
                    i just tested it - seems perfect ...
                    it has 5 VIN and 5 GND tested them all 24.0v
                    stupid questions: is there any fuses on this board? (i only recognize a fuse when i see a standard glass type)
                      The fuse is the white cuboid/rectangle with gold ends, marked on board F1 12A near the power connector.
                      • nathaniel
                        • 35
                        • israel
                        the MOSFETs all have same resault (not shorted - BUT tested onboard is it ok?)
                        the fuse also checks out OK (learned somthing new today
                        • nathaniel
                          • 35
                          • israel
                          is there anything else to check?
                          if i get an inverter card - is it 100% solution or it still can be another card or the CCFL ?
                          thanks
                          • truep
                            • Aug 2010
                            • 373
                            Does this set have a slave inverter on the other side from this one?
                            • nathaniel
                              • 35
                              • israel
                              no - only one that is connected to both ccfl
                              • nathaniel
                                • 35
                                • israel
                                any sugestions? please....
                                  09-06-2024, 05:27 AM
                                • delphi_firebird
                                  Toshiba Qosmio X755 Charging problem
                                  by delphi_firebird
                                  Hello Guys,
                                  I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
                                  - When battery is unplugged i works without any problem.
                                  - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
                                  - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
                                  Can you help me diagnose the problem? I have attached...
                                  10-16-2023, 03:04 AM
                                  09-06-2024, 05:59 AM
