lg32lf20fr
  • willyam1
    • Feb 2012
    • 112
    • israel
    lg32lf20fr
    hi to all.
    problem is- sound ok ther is backlight no pic no osd blank screen
    main board chasis lp91a tcon board 6870c-0266a.
    smd fuse ok 12v ok checked voltage in tcon 12v 3.3v 1.5v 17.3v -6.5v.
    by scoping can see some signal when input is connected.
    hade a few lg with same problem but different chasis and eeprom was the problem but this not shure if screen tcon or main is the problem.
    anyone have an idia?
    thanks willyam
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • netgearnetgear
    TCL 43S423 TCON OR PANEL FAULTY???
    by netgearnetgear
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
    08-20-2025, 06:04 PM
