sanyo dp42746
    sanyo dp42746
    plasma tv picture dull every thing else seems ok no lines
    light in rear marked error is on not blinking there is a blinking led
    1001 on logic board most people have error code 12 so i cant
    find something lick mine 2006 a found in trash tv hope to save it..
    Re: sanyo dp42746
    Probably X-main / Z-sustain board from symptoms described.
      Re: sanyo dp42746
      the pic got bright two or three times since ive had it
      but no more ive removed x main board ebay has some 16-75 dollers
      ill read post on testing caps
        Re: sanyo dp42746
        ive made an order for the X main 10 dollers from tv doctor on ebay
        should be here by the 8th will update then thanks
          Re: sanyo dp42746
          replaced the xmain with a used one. pic not any better
          pic dull not bright looks like maybe not all pix are lit small white dots?
            Re: sanyo dp42746
            Can you provide a picture of the fault?
              Re: sanyo dp42746
              yes i checked some volatages they were close to spec
                Re: sanyo dp42746
                here is a better photo in the dark
                  Re: sanyo dp42746
                  See if adjusting the Yrr and Yfr controls on the Y-main helps, and check the Vs, Va, Vsc and Ve voltages are at or near the specification (within 2 volts.)
                    Re: sanyo dp42746
                    the va,vs, vsc,ve were good on p/s board i dont know how to check the others
                    or what they shoud be.. i see two pots on y-main but no specs.
                      Re: sanyo dp42746
                      Can you provide a picture of your X- and Y-main boards?
                        Re: sanyo dp42746
                        here they are..
                          Re: sanyo dp42746
                          Any chance of a higher resolution picture, so I can see the text more clearly around the adjustment pots? Or just break the board into quarters and take individual shots.
                            Re: sanyo dp42746
                            there in the shape of letter Y bottom vr5001 vr5002 right vr5003 left vr5004
                              Re: sanyo dp42746
                              i cant get much better pic ive.changed some of the vr settings
                              and have much britter pic big improvement..
                                Re: sanyo dp42746
                                Which ones did you change?
                                  Re: sanyo dp42746
                                  vr5001-vr5004 all of them i had a lot of improvement
                                  not there yet looking to do factory reset dont have sanyo remote ..
                                  there are dip switch on t-con on says reset
                                    Re: sanyo dp42746
                                    im checking voltage on p/s board is VSCAN = VSC vsc should be -190 i have test point
                                    marked VSCAN which has -245 by turning pot marked VSCAN nothing changes
                                      Re: sanyo dp42746
                                      It sounds like the pot or feedback circuit may be faulty - excessive Vscan can also damage your buffer boards so be careful about running it too long.
                                        Re: sanyo dp42746
                                        i got voltage down on vscan to-190 by a pot on y sus board now all are correct
                                        there is a VG test point ?
