Safely Discharging a Flyback Transformer.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    What are the procedures to safely discharge a flyback transformer? I watched a video on Youtube and the guy didn't want to repair the TV. He used a screw driver with a jumper wire on it going to a ground on the board and touched the screw driver to the anode wire going into the picture tube. If I hook a screw driver up with a jumper wire to something like the tuner box to ground it, would that damage anything? Thanks.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    Re: Safely Discharging a Flyback Transformer.
    A flyback transformer doesn't have a capacitor. You may mean to discharge the CRT? In which case the typical method is to stick a grounded screwdriver under the anode cap. A spark should be heard, which is the discharge.
    • Spork Schivago
      • Mar 2012
      • 4734
      I guess I do mean discharge the CRT. Don't I have to run a wire from the screw driver to a ground? Or do I just touch the screw driver under the rubber and it'll discharge?
        If you just touch it under the cap, where will the current go? You must ground one end of the screwdriver. Also, it's essential to use an insulated screwdriver.
        • Mrx3750
          • Jul 2013
          • 311
          You would touch the screwdriver and it would discharge.
          However that's a really scary way to do it.
          On most newer CRT TV's discharging the CRT is not a huge concern because they have bleeder resistors that will drain off the CRT's charge in a few minutes after the set's powered off and unplugged. However discharging is still a good idea.
          You could set up a series of high wattage resistors in series from CRT cap to ground if you wanted to discharge without the spark and noise.
            On the other hand, hearing the audible "click" is a good confirmation that the CRT has discharged.
            • Spork Schivago
              • Mar 2012
              • 4734
              This TV is from 2000, I hooked the screw driver to a wire and the other end of the wire to the metal frame that goes around the CRT. I touched the clips under the rubber and didn't hear a pop. I took the anode clips out of the crt and again, touched the screw driver to the clips. This time, I touched it to both clips...and still no pop.
              I'm a little scared of touching the anode clips and seeing if it's discharged. I'd feel a lot safer knowing that it is in fact discharged. Should I assume it has the bleeder resistors?
              I checked the continuity of my setup by touching one probe of my DMM to the screw driver, the other end to the alligator clip and it read 0. So I know there's no shorts in my setup...
              • Spork Schivago
                • Mar 2012
                • 4734
                What makes the metal frame around the TV a ground but not the screw driver? Is it because the metal frame is square? Wouldn't I have to ground it to something on the circuit board? So it's a complete path?
                  The metal frame is ground because the CRT is attached to it. There are ground wires running around it, I think the metal coating or edges of the CRT make it ground.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    It must have those bleeder resistors. I ended up touching the clips directly to the tuner's metal box, nothing. Then I ended up touching the clips with my fingers, nothing.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      Thanks!
                      • Mrx3750
                        • Jul 2013
                        • 311
                        Might I ask why you're discharging a CRT?
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Yup, the OSD doesn't work on this TV. It's a Panasonic CT-36D30B. I cannot find a service menu so I'm going to start randomly pulling components and testing them until I find the bad component.
                          The volume works but it doesn't show any bars, changing the channels work but it doesn't show any numbers or anything. Hitting the Menu button doesn't display anything on the TV.
                          I couldn't really find any info on how the on-screen display works. I found some data sheets for some of the ICs. One's called a MPU and some of the pins said something about closed caption. I think that's where I'll start.
                          When I was trying to work on the board, the flyback's second anode wire that connects to the crt wasn't very long and I couldn't work on it properly. So I had to unhook it so I could move the board out a little more and start unsoldering everything.
                            The OSD on most of these sets (old CRT) works by switching in the OSD generated video, synced to the video signal. You don't see a black shadow of the OSD, so I'd be looking at why the masking circuit, the part which selects between OSD and normal video isn't working. Due to the highspeed circuits you'd probably need a scope to see what info if any is missing. You can also check the local power supply for the microcontroller(s).
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              How much does an oscilloscope costs? How do I tell what and where the masking circuit is? I found what looks like a diode but it doesn't have any markings and it reads open both ways. On the circuit, it's labeled L006. Any idea what this is? My DCA55 meter doesn't recognize it.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                Would the L indicate an inductor? I thought inductors had wires wrapped around them...
                                  L005 is an inductor, and should read shorted.
                                  A decent, used scope can be had for under $50:
                                  https://www.google.co.uk/url?sa=t&rc...51495398,d.ZGU
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    Would this one work? It's a 100MHz model. 97$ with 18$ shipping... http://www.ebay.com/itm/Hitachi-Osci...item3cd434b688
                                    Also, here's an Hitachi V 252 2 Channel 20Mhz Dual Trace Oscilloscope Tested for 94.99$ and 39$ shipping. http://www.ebay.com/itm/Hitachi-V-25...item5d436faf95
                                    I don't think the first one comes with cables and not sure about the second one.
                                    I've never used one before. I don't know much about them. Like what's the difference between the various MHz models and stuff like that.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      It's a lot of money for my girl and I. Hopefully the investment will pay off. I don't really know what you can use them for besides fixing televisions.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        On-line I saw something that said for TV repair, a 100MHz one would be best. Is that true?
                                        • retrotechrestoration
                                          Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
                                          by retrotechrestoration
                                          I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
                                          Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
                                          03-22-2024, 06:50 AM
                                        • bohaboha
                                          can a flyback transformer for USB charger isolate?
                                          by bohaboha
                                          can i use a flyback transformer from an usb charger to isolate galvanically a small diy led tester? or it must be an isolated transformer
                                          01-15-2022, 02:36 PM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
