Magnavox Plasma TV 42mf231d/17 No Picture Need Help
  • mh321
    • Aug 2013
    • 28
    I got this broken plasma TV for free off craigslist, Magnavox/Phillips 42mf231d/17. I am trying to repair it, if it is even worth fixing.
    When I plug the TV in, the front blue LED turns on for a few seconds, then shuts off. When I press the power button, the blue LED lights up and a click from the back can be heard, and that's it, no picture, nothing else. When I press the power button again, the blue LED turns off. The remote the original owner gave me (claims it is the original remote) is able to turn the TV on using either the mute key or a number key. The only key on the remote that turns the TV off is the mute button. The power key on the remote doesn't do anything. When I turned the TV on the first time at home, there were random red, blue, and green pixels on the screen that behaved wierd.
    Inspection of the boards revealed 1 bulging 100uF 50V 105C capacitor on the y main board, which was replaced by one with the same capacitance and voltage rating, but with 85C rating because that's what radio shack had. The new capacitor had no effect on the TV.
    I also tried checking voltages on the power supply like Vscan,Vg, etc, and all values were correct. I also reinserted all cable connectors I could find.
    I also can't access the blinking SDM feature as explained in the service manual. I shorted the 2 SDM points with a screwdriver. The only effect I got was when the front LED was off, when I shorted the SDM the blue LED would come on with a click for a few seconds, and then shut off.
    Then yesterday, while turning the TV on and off, smoke started coming from somewhere near the power button, and there was a very bad smell.
    At this point, is this 7 year old plasma TV even worth fixing? Is it beyond repair? Any ideas on how to fix it or what else can be done?
  • capkid
    • Oct 2010
    • 1339
    Re: Magnavox Plasma TV 42mf231d/17 No Picture Need Help
    This line of TVs isn't one of my favorites to repair. They tend to have PSU, Y-main, and Y-buffer issues that can be expensive to fix and maintain. If you're looking for a learning experience, this one will probably be a good, err, or bad lesson If you're looking for a good TV that won't cost much to fix and maintain, I'd move on to another TV. There are plenty out there.
    LG Plasma Mal-Discharge Correction Service
    • mh321
      • Aug 2013
      • 28
      Does anyone have any other advice? Or does everyone agree that this isn't worth repairing?
      • capkid
        • Oct 2010
        • 1339
        To add: If your Y-Sus blew, you're most likely looking at buying one or both replacement buffers along with repairing the Y-Sus. If you buy used replacement buffers, there's a good chance one or both will blow in short order, taking your Y-Sus out with them. NEW buffers for this TV are normally not cheap.
        • Caleb
          Smokin IC's
          • Feb 2013
          • 645
          Ive got one really close a 42mf230A/37, though with different symptoms. I might be interested in some boards if they are good. Mine has an issue with the power supply, but these are notorious for bad buffers taking out the ymain, replacements are more than it is worth. Check out coppell tv repair blog for the low down on this series.
          Liberating magic smoke one part at a time
          • capkid
            • Oct 2010
            • 1339
            Yep, that's what I experienced. (1) The 42MF231D/17 I have sitting on the floor in a storage area had a bad PSU. I tried to replace several burned components and a couple others in circuit with the fried components - didn't work, so I put it aside. (2) I later acquired a Philips TV that uses the same Y-Sus and buffers; it had a bad Y-main and a shorted buffer, so I had the Y-main repaired and I replaced the buffer with a working buffer from the 42MF231D/17. The TV worked great for a few days, so I sold it on CL. I saw it again on CL two months later (I recognized the person's info in the ad) - picture was out.
            • mh321
              • Aug 2013
              • 28
              I'll try selling it whole for now. Thanks very much for the help.
              • KYBOSH
                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                by KYBOSH
                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                No picture but you hear the TV static (white noise) playing loud and clear.
                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                But it seems they didn't get too far and just left it.
                When I first took a look I was amazed at how pristine the inside looked.
                Its as if the TV had been in a time capsule.
                Caps looked like they were just pulled off the self.
                Copper coils had no sign of corrosion on...
                02-01-2023, 11:10 PM
              • KYBOSH
                Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                by KYBOSH
                Saved this beast from the landfill this weekend.
                Manfactured July 2013 in Mexico.
                I love working on plasma TVs.
                Its been a while but I was lucky enough to find 2 this week.
                The TV powers on and stays on but no picture. Havent checked for sound yet.
                No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                Will start troubleshooting tonight.
                10-17-2024, 01:17 PM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
                Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-07-2024, 05:50 AM
