Samsung LN32B650T1FXZA does not power on
  • scalde
    • Aug 2013
    • 5
    • usa
    Hello, have a few questions. I have the follwing tv and it does not power on. the power on led on the front flashes but not in a patern. i did a quick diagnostics I opened up back cover to inspect caps on power module and they all look good. when I disconect white ribbon cable to main board the backlight on the set turns on. I pluged it back in backlight goes off. i went further and and disconected ribbon cable going to the t-con board. backlight goes back on and now I have the sound (Samsung Chime) from power up, still have front power led flashing on and off ramdomly and no picture. question is where do i start trouble shooting or whats the most common isue with this set. I also would like to find a service manual for it.. any one help me out... Thanks..
    quick note. as i was doing a visual inspection i found I had one of the inductors (L1501) casing broken. I followed the trace and it goes to audio out speakers. dont think this could be the cause but i would like to replace it any one familiar it i would like a part number..
    Sal
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung LN32B650T1FXZA does not power on
    Can you post pics of the board layout? Off hand, it sounds like a bad t-con or main board (main board seems more likely). Check your t-con fuse.
    LG Plasma Mal-Discharge Correction Service
    • scalde
      • Aug 2013
      • 5
      • usa
      ok here you go, I included a picture to show the inductor thats damaged. where is the fuse to the tcon board?
      • capkid
        • Oct 2010
        • 1339
        Here's the fuse.
        That inductor doesn't look good. I may have misunderstood your problem statement and tests. Did you try connecting the main board to the power supply and disconnecting the t-con from the main board when you got the chime and a backlight?
        • scalde
          • Aug 2013
          • 5
          • usa
          yes sure did..
          PS + Main Board + tcon = no picture no sound
          PS + Main Board = backlight plus startup sound
          • capkid
            • Oct 2010
            • 1339
            Does your t-con fuse check out?
            • scalde
              • Aug 2013
              • 5
              • usa
              yes fuse is good, any test points that I could check? also any idea on manufacture of inductor, its 15uh but thats all that i know. i would love to get get part list and order that inductor. if anyone has a schematic that will help me alot
              thanks for your help
              • capkid
                • Oct 2010
                • 1339
                I tried to search for your model num in Tom's database, but I couldn't find any service manuals by that model num. Here's the closest I could find: http://www.toms-service-manuals.com/...&Search=Submit
                The parts list for the LN32B530 shows L9001 on the main board as 15uH. I'm not sure if this is the same part. Someone else can suggest a good replacement. The inductor has the following info:
                Code No: 2704-000018
                Description and Spec: INDUCTOR-SMD-ARRAY;15uH,2000mA,2,0.124oh
                  I've had shorted t-cons on these stop the TV from powering up. However, it's a good idea to isolate the panel as well, in case a short on the panel is causing the problem.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • mrtek
                    Samsung UN43NU6950FXZA No power
                    by mrtek
                    Hi
                    Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                    Main fuse = OK
                    Back light LED = OK. Power them with aux power source
                    LED output = OK 156V
                    I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                    Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                    07-20-2025, 08:06 PM
                  • hill01
                    Samsung UE75MU7009TXZG Endless Power Cycle
                    by hill01
                    Hi everyone and thanks in advance for any help I might get here
                    My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                    About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                    Since a few days, the TV won't turn...
                    11-17-2021, 02:52 PM
