Lg 50pc3d blinks once click shutsdown
  • NasTech
    • Sep 2011
    • 58
    The Problem am having is the tv when the power button is press the front led goes from red, green then back red. It startups ones then shutsdown. The voltages i read on P800 Connector
    Press Power Stutsdown
    P800 PINS
    4.83v 1. AC-D 4.85V
    4.53V 2. RL-ON 0V
    5.03 3. STANDBY 5.04V
    3.6V 5. VS-ON 0V
    4.66V 6. 5V-D 0V
    5.02V 7. M5V-ON 0V
    5.03V 8. STANDBY 5.05V
    3.32V 10. NC 3.34V
    5.98V 11. 6V 0V
    4.53V 13. 3.3V 0V
    The Connector P802/P803 Voltages startup then stutsdown.
    But i'll disconnect y-sus cables from PS the voltages Vs-230v then drop fast and stay at 4v, Va-66v then drop fast to 0v but the 5v-4.98 and stays there.
    Next I disconnected P800 from the main Board jump 470 resistors from standby to rl-on and m5-on PS voltages reading 6v-6v, 12v-12v, 19v-19v, 3.3v-0v, Vs-0v,Va-0v and 5v-5v
    Disconnected P804 & P805 voltages reading 6v-6v, 12v-10v, 19v-17v, 3.3v-0v, Vs-0v,Va-0v and 5v-5v
    jump 470 resistors from standby to rl-on, m5-on and vs-on PS shutsdowns
    Feel the problem is in the Vs &Va Section of PS But Any direction to solve this problem welcome
    Patrick
  • NasTech
    • Sep 2011
    • 58
    Re: Lg 50pc3d blinks once click shutsdown
    Pics
    Please Help
    • capkid
      • Oct 2010
      • 1339
      Are your fuses good on the sustains?
      LG Plasma Mal-Discharge Correction Service
      • NasTech
        • Sep 2011
        • 58
        All fuses are good
        • capkid
          • Oct 2010
          • 1339
          It does seem like you have a PSU issue. I found a few repair kits that might offer some clues of things to check:
          http://www.ebay.com/itm/LG-Zenith-Pl...item1e75cd8115
          http://www.ebay.com/itm/LG-Zenith-Pl...item27c6c6d076
          http://www.ohmsupplies.co.uk/Repair-...55-EAY32957901
          Edit: Sorry, I just noticed that your board is different. I didn't realize they made a few different PSUs for this TV. They seem to be interchangeable, though.
          • NasTech
            • Sep 2011
            • 58
            So just replace the Power supply, But i really want fix it doe
            • capkid
              • Oct 2010
              • 1339
              You could try replacing the PSU, do more testing to try to fix this one, or see if there's a reputable repair service. The one thing that would make me do more checking in general is that the VS and VA voltages do come up to spec at some point.
              • NasTech
                • Sep 2011
                • 58
                Vs goes up to 230v is that normal or is that what causing the Power supply to shutdown
                  230V is much too high. 185V to 190V is typical for these supplies. Check your multimeter's battery is good. Also, check Va does not exceed 65V.
                  • NasTech
                    • Sep 2011
                    • 58
                    Vs reading 230v-259v and Va 66v-79v then Power Supply shutsdown, Any diagram for the Power Supply
                    Also New Meter and Battery
                    • capkid
                      • Oct 2010
                      • 1339
                      Ugh, sorry, I'm working on about 4 hours sleep. Thanks for catching that, Tom.
                      • NasTech
                        • Sep 2011
                        • 58
                        Thanks Guys for the helpful info.
                          If Va is 79V, I would be seriously worried about the plasma panel itself surviving such extreme overvoltage. Check your multimeter battery.
                          • Biruslapio
                            Panasonic P58V11B 8 and 12 blinks error "fix"
                            by Biruslapio
                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                            04-13-2021, 07:13 AM
                          • Nairolf
                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                            by Nairolf
                            I have a Samsung DM32D display.
                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                            Here’s what I have tried so far:
                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                            08-24-2025, 03:47 AM
                          • Andre Gilbert
                            by Andre Gilbert
                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                            11-20-2024, 08:52 PM
                          • Taurus12
                            Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                            by Taurus12
                            Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                            I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                            i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                            Any recommendation on what I have to do next? Thanks in advance
                            06-10-2025, 05:05 PM
                          • jchon
                            Sony A1e 5-blinks help
                            by jchon
                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                            I found the service manual, which was critical to know where to probe.
                            https://www.manualslib.com/manual/20...1e-Series.html
                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                            Unfortunately the 5-blinks...
                            06-28-2023, 11:52 AM
