Vizio VO320E Bad Power Supply Board?
  • alja
    DIY Junky
    • Aug 2013
    • 47
    Re: Vizio VO320E Bad Power Supply Board?
    Thank very much Tom, I really appreciate your time and patience, I will post results once I get the new one in.
    Again,
    • alja
      DIY Junky
      • Aug 2013
      • 47
      I just pulled out the diode and the reference is MUR460 / 937 but I cannot find the 937 is there any way to replace it how can I choose the correct one?
      And off course you were right, after pulling out the diode I test the other one and gave me 425
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        I think you just need the first portion MUR460. Datasheet attached below
        Liberating magic smoke one part at a time
        • alja
          DIY Junky
          • Aug 2013
          • 47
          Thanks Caleb, you are right I found that the second number has to do with the manufactured date. Ordering ......;-)
          • alja
            DIY Junky
            • Aug 2013
            • 47
            Just for reference...., I got the diode, replaced it and is working good!
            thanks
              Fantastic to hear! Thanks for the feedback.
              • Ashroyer05
                • Sep 2013
                • 162
                • U.S
                #47
                It's cool to see this posting. I have the same problem with my vizio vl320m. I went over the power supply the other night and found a bad diode, the same one under the heat sink. I will order and hopefully I will get the expected voltages. I found that before seeing this posting, but this posting serves as a confirmation. This site is a great tool!
                • inflitedan
                  InfliteDan
                  • Oct 2013
                  I also have this same Vizio VO320E power supply (DPS-172EP) that has me a bit stumped. No output on any rails. Not even on the +5vSB. Main fuse is good. All caps are good. Initially, I found 2 bad MOSFET’s (Q700 & Q708) I replaced them and still no power anywhere. I followed this post up to #28. As suggested I checked the DC voltage across C802, it’s 180vdc. Reading on to post #30, the voltage across C903 is alternating between 9 and 13vdc. Post #36… Diodes D802 & D803 seem to be OK. Thoughts?
