Sony KDL-46Z4100 another TCON problem?
  • cwmcobra
    • Aug 2013
    • 35
    Re: Sony KDL-46Z4100 another TCON problem?
    I see now that you are right; no need for another picture. F100, 4A/72V near LVDS connector and F101, same fuse on left. I should check them both?
    Thanks,
    Chuck
      Do you see the two fuses I mention above?
      • cwmcobra
        • Aug 2013
        • 35
        Yes.
          Then you just have to check and see if you get DC voltages at both ends of the fuses with ref to chassis ground.
          • cwmcobra
            • Aug 2013
            • 35
            OK, thanks. I'll check and report back.
            Chuck
              You can use Ohm meter to check if they show less than one Ohm resistance first. You know how to test the fuse, right?
              • cwmcobra
                • Aug 2013
                • 35
                12V DC at all both ends of both fuses.
                • cwmcobra
                  • Aug 2013
                  • 35
                  And yes, less than 1 ohm resistance across both fuses.
                  • cwmcobra
                    • Aug 2013
                    • 35
                    I tested resistance by probing the two ends of the fuse with the two probes of the VOM. I tested voltage by holding the negative probe from the VOM to a chassis screw and the positive probe to each end of each fuse. I hope that's correct......they are kind of tiny.
                      That is correct, and when testing the DC voltages, the TV must be turn on. When Ohm test , TV must be unplugged.
                      • cwmcobra
                        • Aug 2013
                        • 35
                        Yes on both counts and as reported, the resistances were both below 1 ohm, essentially zero. And I had 12V at each end of both fuses with power on.
                        • cwmcobra
                          • Aug 2013
                          • 35
                          I suppose this means that there is no obvious problem with the TCON board? By the way, I noted that if I power the set on with the LVDS cable disconnected from the TCON board, it does not go into the 14 blink failure mode. Stays on, but obviously, with no picture.
                            Do you get the same error with the original T-CON board?
                            • cwmcobra
                              • Aug 2013
                              • 35
                              No, the colored vertical stripes are gone. But the TV won't stay on. It shuts itself off after about 30 seconds and the red light on the front panel blinks 14 times repeatedly. It doesn't stay on long enough to hook up a source and test for an appropriate picture.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Ok im thinking faulty lvds cable from mainboard to tcon. Sonys will 14 blink when the mainboard doesnt get confirmation from the tcon. Sense you plugged your original mainboard in your still getting this error I would assume that you had moved the LVDS cable and it's no longer making proper contact with the t-con board
                                • cwmcobra
                                  • Aug 2013
                                  • 35
                                  Let me clarify what I've done. I started with the colored vertical stripes as shown in my original post. I purchased a used replacement TCON board and after installing it, found that the vertical stripes were no longer present, but the TV would shut itself off and display 14 blinks of a light on the front panel. After reading the posts from Bud last night, I checked continuity of the fuses on both the old an replacement TCON boards, and both showed nearly 0 ohm resistance. I also checked voltage at both ends of each fuse on the TCON board on the replacement board only. All of those measurements were 12V DC. I did not get the autoshutdown with the original TCON board, just the vertical stripes.
                                  So that's where I am now. I have not checked voltages across the fuses with the original TCON board installed. Should I do that? And can I check the LVDS cable using an Ohmmeter to check resistance of each wire? Any other suggestions? I appreciate them all!
                                  Cheers!
                                  Chuck
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #37
                                    Hi - yes you can check the lvds cable for continuity.
                                    Maybe you can do the test from connector to connector
                                    (sometimes there are tiny test points on the boards)
                                    This would mean you are testing both the cable and verifying that it has a good connection at the same time.
                                    • Davheel
                                      • Mar 2013
                                      • 8
                                      Hi just wonder have you resolve the issue?
                                      • cwmcobra
                                        • Aug 2013
                                        • 35
                                        Still unresolved. I confess I haven't had much time to spend on it with travels and other time constraints. I did look at it again yesterday and have concluded that testing continuity on the cable is a no go for me. The wires and terminals in the connectors are WAY to small for me to check with my VOM probes. And some of the terminals are almost hidden in the connectors.
                                        So where do I go from here? I don't know. If the experts here have any other ideas I'd love to hear them. I could make good use of the TV if I could fix it, but haven't found the right "magic" yet......
                                        Cheers!
                                        Chuck
                                        • Keithj84
                                          • Feb 2014
                                          My tv has the stripes but when I first turn it on the picture is fine. Then the picture freezes for about 20 seconds and the color inverts then changes to stripes. The picture returns if I shut it off and back on again or sometimes it will come back after a few minutes without me having to shut it down. Any ideas of what might be going on with it? Thanks for any assistance
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
