Toshiba 32hl66 32" LCD TV, won't light up
    Re: Toshiba 32hl66 32" LCD TV, won't light up
    Is this the one you have?
    http://assets.shopjimmy.com/media/ca...1926006145.jpg
    There are SMD fuses so check them out, also check and see if it does have 24vdc on both ends of the fuse when TV is on.
    • Mrx3750
      • Jul 2013
      • 311
      Yep thats it. Found em on ebay by part number.
      So these SMD fuses. What if I found a bad one and bridged it? What's the worst that could happen?
        Smoke, fire, destruction.
        However, if you tested there to be no short before bridging the fuse: nothing. It'll probably work just fine.
        • Mrx3750
          • Jul 2013
          • 311
          Welp... one way to find out. I'll see about looking it over later.
            Yes, check all the fuses. If you find one that is blown, a test can be done to see if there are any shorts or not.
            • Mrx3750
              • Jul 2013
              • 311
              I see two fuses. One gives a solid reading of less then 1 ohm. The other was a bit more flaky, the reading kept jumping a bit.
              • Mrx3750
                • Jul 2013
                • 311
                Okay it's not the fuses.
                  Huh?
                  "The other was a bit more flaky, the reading kept jumping a bit."
                  Also, there are three fuses on these boards. Check F101 too. It's smaller than the other two.
                  • Mrx3750
                    • Jul 2013
                    • 311
                    Mmm nope, F101 tests as good.
                    The flaky reading was my multimeter, didn't have a good enough connection.
                      Any way to test the voltage on each end of the fuses? Red probe on each end, black going to the chassis of the TV.
                      • Mrx3750
                        • Jul 2013
                        • 311
                        Uh nope. That inverter is installed upside down and buried under a lot of crap. Testing would be... difficult to say the least.
                        I have the inverter board out of the TV now. can I do some tests with my multimeter?
                        • Mrx3750
                          • Jul 2013
                          • 311
                          Hey guys, I finally got a new inverter board for this TV. I installed it and for the first time the panel lit up!
                          However, the panel lights up for one second, then goes black again. it lit up enough though to tell me that the TV is tuned to channel 34 and is receiving static.
                            It could be either a defective inverter or there is a bad bulb in the panel. Can you perhaps connect the TV to a full white image over VGA, then turn the inverter on (perhaps disconnect BL ON and jumper it manually to get a 1~2 second flash.) If you see a dim bar, the panel has a bad bulb. Tricky, but not impossible to replace.
                            • Mrx3750
                              • Jul 2013
                              • 311
                              That would be difficult. I don't know how to get the TV into VGA mode, and I can't figure it out with the screen dark.
                              If it's of any help, the static raster looked even, no dim areas.
                              I did have a bit of trouble getting all the connectors in. I'm gonna see if I have a loose one.
                              Oh, something else too. The inverter board is an RU E206453 board, model V144. However the replacement while bearing the exact same model, has two of the mounting holes missing and the circuitry is a bit different. Does this matter?
                                A difference in the inverter could matter.
                                • Mrx3750
                                  • Jul 2013
                                  • 311
                                  Tried it again and noted that the inverter was buzzing while the panel was lit.
                                  • Mrx3750
                                    • Jul 2013
                                    • 311
                                    All right! I finally have the damn thing working!
                                    I ordered a tested and working inverter board off of ebay. It arrived today, put it in and finally after all this time, the TV works!
                                      09-06-2024, 05:27 AM
                                      09-06-2024, 05:59 AM
                                      09-06-2024, 05:33 AM
