Samsung DLP Light Bulb Replacement
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Hey everyone. Friend of mine has a 50" DLP set and the bulb blew today. I was just wondering if anyone could recommend a reliable, quick supplier with good quality bulbs. I just don't want him to end up with something cheap that's just going to die quickly. His original made it 5 years.
    He's going to shoot me the model number shortly. I'm taking him a 32" loaner tomorrow so he has something to watch.
    Thanks,
    Aaron
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Samsung DLP Light Bulb Replacement
    Curious too since I'm not familiar at all with these but is this a standard type bulb with a filament? Reason I ask is he said it didn't look blown but I had him check for continuity and it shows open.
    Scratch that. Found the answer and can't be tested like that.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Got him to check the error code and its all three lights blinking which definitely indicates a lamp failure. Model number is hl50a650c1f so back to the original question of where to get it if anyone has a recommendation.
      Thanks,
      Aaron
      • RON_CET
        • Jun 2012
        • 217
        Shopjimmy good source either Phillips or the Osdram lamp might would stray away from the Osdram Neolux lamp not good results with that one
        Ron Driver,BSEE,CET,ISCET,NESDA
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Thanks. Found this one. Any opinion? I'll check out the Phillips equivalent.
          http://www.electrified.com/p-214-dng...ment-lamp.aspx
          Checked Shopjimmy but it's out of stock.
          • RON_CET
            • Jun 2012
            • 217
            be careful of the Chinese knockoffs there cheap and don't hold up ,I have used shopjimmy exclusively they have low failure rate and will replace if failed during warranty with no issues my opinion i would use the lamp only route @ S/J and just replace the bad lamp using your friends same housing
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Thanks again for the advice. I've bought numerous LCD parts from shopjimmy. I'll check with them and see what they have.
                09-07-2024, 05:50 AM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
              • marcinq
                Samsung UE60KS7000 No Standby Light
                by marcinq
                I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                05-26-2025, 11:36 AM
              • ChristianBr01
                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                by ChristianBr01
                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                04-23-2025, 01:48 AM
                09-06-2024, 11:40 PM
