I am having a problem with my TV and am wondering if it's worth repairing. I am an EE and have no problem soldering or replacing boards. I took the TV apart and do not see any obvious damage to any of the boards. The power supply looks clean with no sign of heat damage or bad caps. The TV basically works, but the display seems to have some ghosting, almost like the refresh rate has been slowed way down. Attached is a picture showing what it looks like. Any idea where to look next?
Samsung LN-T3253H Display Problem
Re: Samsung LN-T3253H Display Problem
Double images like that can be caused by bad tab bonding on the LCD panel and the PCB.Never stop learning
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
by KYBOSHCame across a 75" QLED TV with restart-backlight no boot and it was headed to the dumpster. Asked the owner to let me have a crack at it. They said the TV went out during or soon after a thunderstorm. I noted this but didnt out too much stock into it as it could have been anything.
VERY big TV and i was worried about the display cracking during the moved as well as the repair but it was alright as i try very hard to handle with care.
In the video (zip file) you can see' as the TV tries to start up, tbere are a lot of gaps in the backlight so I immediately suspect... -
Hi All,
Need help.
I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard.... -
by Neptune06Hello,
I have a display problem (bad size and color) on a Samsung U28E590D and i'm wondering if someone have access to the service manual for this monitor. I used a faulty Lenovo thunderbolt hub connected to it and now i suspect a problem on the HDMI part of this monitor. The main PCB board part number is: BN94-10748G.
Thanks for your help.-
10-02-2023, 05:30 AM -
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
- Loading...
