TH-42PD60U 10 blink code
  • jkomorek
    • 37
    I followed the troubleshooting chart found here for 10 blinks before presing the power button http://tsn.pstc.panasonic.com/PASS/o...ing_Charts.pdf and I made it to the final step in which I am supposed to look for 14v coming off of P10 connector.
    I am actually getting 17v off of that connector. I used a schematic of the board found here http://www.toms-service-manuals.com/...&mfg=Panasonic and I traced the 17V back as far as D536 which I have highlighted in the attached jpg. There is a transformer just before the diodes, but I see any marked voltages before that so I'm not sure how to troubleshoot.
    This is where I am getting stuck. When I plug in the TV I get 3 (sounds like 4 actually) quick successive clicks, which from other posts I have found here indicates that I am "not getting 14v" at P10, so I think that I should assume it is the PS. However, I am really not confident about this. Any advice?
    Re: TH-42PD60U 10 blink code
    I believe 10 blinks is 15V failure, which could be over-voltage. Causes can include bad feedback circuit, bad voltage references and bad capacitors, the latter being rare on Panasonic sets.
    • jkomorek
      • 37
      Thanks, Tom. Any suggestions on how to continue my troubleshooting to find the damaged components?
        Try to attach a 15 ohm, 20 watt resistor to the 15V line. If it stays as 17V, suspect feedback/reference, if it drops, suspect capacitor or other fault.
        • jkomorek
          • 37
          Ok, I just ordered the parts to test this with. Out of curiosity, how did you derive the resistor values and how will this tell me that the issue is reference as opposed to a PS fault?
            17V / 15 ohms = approx 1 amp load
            The 15V line on these is usually capable of around 3 to 4 amps.
            Power dissipation determined by I^2 * R = 15 ohms * 1 amp = 15W. Select 20W to be safe.
            Power supply feedback will act to keep the output at the setpoint, even if the setpoint is wrong. If this circuit is at fault, then the output will not significantly drop under load. If it does drop, it points to another fault in the power supply.
            • cloo
              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
              by cloo
              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
              After doing a factory reset this problem was gone and the picture was back to...
              01-06-2025, 06:02 AM
            • rmacintosh
              Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
              by rmacintosh
              I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
              The symptoms of the tv ar as follows:
              • Plug AC in to back of TV
              • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
              • The 3 blink code is given by the power LED
              • If the TV is unplugged and then
              03-14-2020, 12:24 AM
              LCD LED TV Service Menu Codes
              ALL LCD LED TV SERVICE MENU CODES
              Service Menu Code with Board Name
              China Universal Board / Jumper Board Service Menu Code
              Changhong Ruba Service Menu Code
              Ecostar LED TV Service Menu Code
              Orient LED TV Service Menu Code
              Haier LED TV Service Menu Code
              TCL LED TV Service Menu Code
              Samsung LED TV Service Menu Code
              LG LED TV Service Menu Code
              Videocon LED TV Service Menu Code
              Supra LED TV Service Menu Code
              Toshiba LED TV Service Menu Code
              Symphony LED TV Service Menu Code
              Veste/ LED TV Service Menu Code...
              10-31-2024, 03:58 AM
            • reporter1979
              2 red blink code on old led tv Sony KDL-40W2000
              by reporter1979
              Hi all, the TV KDL-40W2000 was flashed by a lightning.
              Firstly I got the 3 red blink code.
              Following other threads I changed the power supply board and got always 3 blinks.
              So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
              The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
              What else can I do?...
              02-17-2023, 11:50 AM
            • Curtissimo
              HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
              by Curtissimo
              Hi everyone.
              I have a HP Elitebook 850 G8.
              Serial: 5CG2324XM0
              ProdID 6L8D5EC#ABA
              It has a Winbond W25Q256JVEN Chip.
              I need to remove BIOS Password.
              I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
              Attached my dump.
              I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
              I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
              What I did:...
              08-26-2025, 04:42 AM
