LG LCD 32LH40 no picture but sound and backlight
  • Sevenqi
    • Jul 2011
    • 292
    Got another 32" LG TV recently, model 32LH40, the problem is when turn on the TV, everything works good, but a few seconds or so, there picture gone, but it has sound, the backlight is on. NO display when I press menu.
    This is the similiar problem with another same TV, though that one can work longer (half an hour).
    I suspected the t-con, so I changed the t-con with another same model tv, but the problem no change. So the problem may be from main board, the panel is unlikely becuase it works perfect when turn on.
    Any idea on the main board to stop the picture signal? What I can find is that the 12V power output, when opicture is normal, it reads 11.8 V, but when the picture gone, it reads 12.08V.
    BTW, when the picture gone, I measured the voltage in the T-con, it reads normal.
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • maneatingmonkey
    Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
    by maneatingmonkey
    I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
    There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
    03-27-2024, 07:17 AM
  • stylishconsultant
    un60j620dafxza - Samsung No Display Problem
    by stylishconsultant
    Hi All,
    Need help.
    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
    09-04-2024, 03:26 AM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
