LG- 42LK450-UB.CUSY.LH Snowy Display
  • kylekasey
    Lost
    • Jun 2013
    • 15
    History: I replaced the Main Board and Power Supply. The TV now powers up but the display, including menus, is snowy. I replaced the T-Con board and that had no effect. The power-up screen / time screen is clear which makes me think the screen is not damaged. Could I have gotten a wrong replacement main board? firmware? Any help will be appreciated.
    Original Main board : EBU61369602
    Replacement : EBR73308816
    Re: LG- 42LK450-UB.CUSY.LH Snowy Display
    Can we see the time screen? Odd that the main menu is affected but not the time screen?
    • kylekasey
      Lost
      • Jun 2013
      • 15
      Very bad picture, but it flashes off so fast its hard to catch it. But the LG and blank time are clear with a solid black background. Then the "no signal" animation starts with the snow..
      Thank you for the help!
        Hmm... If you turn down the TV's backlight or brightness setting does it reduce? (crazy idea)
        • kylekasey
          Lost
          • Jun 2013
          • 15
          Changing the brightness has no effect.
          • kylekasey
            Lost
            • Jun 2013
            • 15
            Does that mean it could be the main board?
              It looks like a main board issue to me, but first I would try a factory reset:
              Hold MENU on TV and MENU on remote. Hold for around 10 seconds.
              If password prompt shows type 0000 or 1234.
              When the service menu appears, select the RESET option.
              • truep
                • Aug 2010
                • 373
                I had a 32" samsung that had a similar problem. The previous owner had replaced the main board with one from a 46" set. He used the number on the board, not the one on the sticker. Maybe the same problem?
                • kylekasey
                  Lost
                  • Jun 2013
                  • 15
                  That is my thought too. The board with matching numbers was for a 42lk520 not a 42lk450.. If the factory reset suggested above doesn't work I will order another board and give it a shot. I also wondered about a firmware issue. This model came with either a VA or IPS screen...I am not knowledgeable enough to understand if that would be a factor.
                  • kylekasey
                    Lost
                    • Jun 2013
                    • 15
                    Can I access the service menu with an after market remote? I don't have the original.
                      Yes, as long as it has the MENU key on it.
                      • kylekasey
                        Lost
                        • Jun 2013
                        • 15
                        I have the factory remote, but I am still unable to access the service menu. I tried holding the remote menu button + TV menu for 10 seconds.
                          OK, let's try the alternate method. Open the main menu by pressing MENU (on remote or set), release the key, then hold MENU on the set. If the menu goes away, try opening the menu again but repeat with MENU being held on the remote control.
                          • kylekasey
                            Lost
                            • Jun 2013
                            • 15
                            Sorry, that method did not work either.
                              Hmm, in which case, this might be a sign the main board is bad in some way or the combination is different for this set.
                              • kylekasey
                                Lost
                                • Jun 2013
                                • 15
                                ok I can bring up the password screen. I used the IR LED attached to my cell phone trick. 0000 or 1234 did not work...
                                • kylekasey
                                  Lost
                                  • Jun 2013
                                  • 15
                                  I can NOW access the SERVICE MENU Password: 0413
                                    OK, do you see a "Reset" option?
                                    • kylekasey
                                      Lost
                                      • Jun 2013
                                      • 15
                                      Sorry I have been sick a few days. I see all the Tool Options but no RESET.
                                        Can you post a picture of the service menu?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
