crown ctt3207w lcd tv
    Hi all I picked up this set today with greeny blue vertical line. It does not go all the way to the top, could this be a panel failure or dry solder joint. I have take lcd panel ribbon cables our and re seated them no joy
    Re: crown ctt3207w lcd tv
        The panel is bad, common with some older LCD panels.
          thought as much tom, i had a hunch it was a bad panel when they said you could see the blue line when you turned the set off, i had to change two blown and bulging caps. apart from that all the boards look good, cheers tom
