Medion MD41527 PS b/d hissing/crackling noise
  • notallbad
    • Oct 2012
    • 1190
    Re: Medion MD41527 PS b/d hissing/crackling noise
    Replaced the 2.2uF 400V cap and its still making the noise.
    Any ideas anyone please or do I just need to keep changing component?
    Thanks again
      I still think it's that inductor/coil near the cap.
      • notallbad
        • Oct 2012
        • 1190
        What can be done about that? What can it be replaced with?
          Not much... Could be a minor crack in the core, leading to high frequency oscillation, or worn enamel on the wires. You can try using glue, but it may not work.
          • notallbad
            • Oct 2012
            • 1190
            Yes, already tried glue and didn't help.
            So a replacement then?
            What am I looking for? Inductor/Coil How many uH's?
            • notallbad
              • Oct 2012
              • 1190
              Yes the insulator looks a little worn.
              • notallbad
                • Oct 2012
                • 1190
                So according to schematic its one of these
                CR-18-LP3009/86.4UH
                  I reckon if you could get this to fit it would work fine.
                  http://uk.farnell.com/panasonic/elc1...064/dp/1749178
                  • notallbad
                    • Oct 2012
                    • 1190
                    Before changing that cap the noise would change according to touching and moving the cap but now it has been replaced there is no change when touching/moving it.
                    The sound is now with the cap on the other side of the coil.
                    • notallbad
                      • Oct 2012
                      • 1190
                      So what could it be if I replace the coil and its still doing it?
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Tom66: I was thinking about this, could a bad capacitor on the secondary side be causing instability in the smps, resulting in this? Like, high peak currents could be causing the capacitors' foil plates to vibrate? I know this is part of the PFC circuit.
                        Notallbad: have you tested the other blue capacitor?
                        Muh-soggy-knee
                        • notallbad
                          • Oct 2012
                          • 1190
                          Hi
                          Thanks for response.
                          No not tested it, only have a cap meter, not esr or lcr meter.
                          The one I (replaced) removed was spot on 2.2uF with the capacitance meter.
                          I understand your comments and I was wondering that myself and thought about checking/replacing the secondary caps just to see.
                          Though I was wondering if the bridge rectifier could have something to do with it?
                          • notallbad
                            • Oct 2012
                            • 1190
                            The other cap, MM105K, measures just under 1uF.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              You can take a plastic straw, put it up to your ear, and poke (listen) around to see if it is the capacitor making the noise.
                              Muh-soggy-knee
                              • notallbad
                                • Oct 2012
                                • 1190
                                Funny you should say that, just this afternoon I was doing exactly that and although I could hear noises from most components there was a cap that sounded like it was making a noise rather than being transmitted through the ccts or via vibration. Yet to check it out!
                                As a note : It is on the secondary side.
                                I think I shall be removing and check all the caps anyway even though they do look OK.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Replaced all electrolytic caps on secondary side and the coil as suggested to no avail so looks like I'm gonna have to give up on this one, shame.
                                  Also the on/off rocker switch was crackling/arcing too when switching it on and off so have replaced that too!
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Actually, could you test that grey capacitor that is in between L1 and the main transformer?
                                    Muh-soggy-knee
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      Reads 0.02 uF and has .022 printed on it!
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        From reading topfli8979's thread 'Magnavox LCD 37mf437/37 chirping' and seeing a cap and diode repair kit that apparently repairs the fault it got me to look at the board again in hope I would discover something.
                                        Of course I don't know what 'chirping' is exactly so it may be what this board is producing.
                                        I would have thought if a diode was shorted or oc it would give different results but anyway decided to remove to 'test'.
                                        SB360 Schottky barrier rectifier - DMM diode test reads 246 and 20k ohm test reads 257, OL with probes reversed
                                        P6KE200A 600 Watt transient voltage suppressor - DMM diode test reads 755 and 20k ohm test reads 12.76k, OL with probes reversed
                                        Not sure these tests are conclusive believe I need a variable PS for the suppressor.
                                          Chirping is bursts of pulses, different fault to yours.
                                          • badcappo
                                            Dead Thinkpad E15, hissing noise from BQ25710
                                            by badcappo
                                            Hello there, got a Thinkpad E15 on the bench, almost no vital signs. Only things: Power button white LED flashes several times when USB-PD gets connected (number of flashes varies from three up to twelve times, sometimes no reaction at all). Battery charge indicator LED stays orange. Most interesting is hissing / whining sound from Battery Charge Controller IC BQ25710 on the keyboard side of the main pcb. Board fuses tested and intact, no shorts found so far. BQ25710 is also the only thing on the board to become warm in thermal image (below 70 °C). Thanks for any hint.
                                            03-09-2025, 08:23 AM
                                          • tony359
                                            by tony359
                                            11-28-2023, 05:18 AM
                                          • BlackBeetle
                                            MEDION AKOYA S15450 MD 63650 MSN: 30030203
                                            by BlackBeetle
                                            Hello, I have a problem with a Medion notebook.
                                            https://www.medion.com/de/service/pr...etail/30030203
                                            MEDION AKOYA S15450 (MD 63650) A-DE N MSN: 3003 0203 with Windows 10 64x
                                            The keyboard makes random entries and I don't seem to be the only one. Someone on this board has the same problem. I had BIOS version 207 installed and the BIOS version that Medion Support offers here as 209.
                                            https://community.medion.com/t5/Note.../104097/page/2
                                            Bios Version...
                                            08-09-2024, 05:50 PM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • dicky96
                                            DynAudio DBM50 Monitor Speaker - loud hissing noise
                                            by dicky96
                                            Hi guys
                                            I have a DynAudio DBM50 here - it makes a loud hissing noise.
                                            It sounds just like an FM radio with no antenna (or tuned off-station). The volume of the hissing fades up and down, sometimes drops to almost nothing then comes back loud. It occasionally makes a loud bump noise too.
                                            It does this even with nothing connected to the audio input XLR
                                            Any suggestions?...
                                            11-09-2020, 08:45 AM
