LG Plasma 50PA5500
  • Fletch
    • Sep 2013
    • 16
    Re: LG Plasma 50PA5500
    I do, and when I get some time and resistors this weekend I'll go through the testing steps mentioned in this thread. I didn't feel it necessary to start a new thread without completing all the recommended tests first. I was just curious about the board codes in the meantime.
    • capkid
      • Oct 2010
      • 1339
      Check your sustain voltages:
      Y-Sus: VSC, -Vy <---There should be two resistors near the edge of the board that are labeled VSC and -Vy (locations R273 and R272). Place your leads according to the + and - markings to check each of the voltages. Note: This is based on a EBR73763201 Y-Sus. If your Y-Sus is different, your test points may be in a different location.
      Z-Sus: Vzb (Zbias) <-- Resistor @ location R412 based on EBR74306901 Z-Sus. Again, if your sustain is different for some reason, the location may not be the same.
      LG Plasma Mal-Discharge Correction Service
      • Fletch
        • Sep 2013
        • 16
        Thank you capkid. I did get a thread started. I will check those voltages and post in my thread shortly.
        • Fletch
          • Sep 2013
          • 16
          https://www.badcaps.net/forum/showthread.php?t=31394
          • Boogie2004
            • Sep 2014
            • US
            #65
            Originally posted by tom66
            I meant that the screen glows slightly when powered, but in this case, it apparently does not. In which case you will need to make two jumpers on the power supply to turn it on. You will need to acquire some resistors with leads ("through hole resistors.") Any value from 100 ohm to 470 ohm is usable, but lower is better.
            There is a grid of pins on the power supply. The connector must be unplugged on the main board end (the board with video inputs) and left connected to the power supply.
            Resistor must be connected between STBY and M_ON and STBY and RL_ON; the jumper on the control board should also be present and the appropriate cable unplugged too.
            Then the screen should come on and show test patterns if it is a main board issue, otherwise it may be a power board, sustain board, or other fault.
            Tom,
            Hi. I am new here but I am having the same problem. I tried the jumper and the 2 resistor but the tv will just click and then another click. Nothing on the screen. How will I know if its a power supply? Thank you.
              Do you have Vs & Va from your power board?
              • Boogie2004
                • Sep 2014
                • US
                #67
                Good evening Tom. I will look at the old threads on how to measure that Vs & Va. I will try it tomorrow and will let you know the result. Thanks
                • Boogie2004
                  • Sep 2014
                  • US
                  #68
                  With the meter on 200V, main board plugged
                  Vs= 9.8 -11
                  Va= 0
                  With main board unplugged
                  Vs = 4.4 - 6.0
                  Va = 0
                  • easternversant
                    • Dec 2015
                    • 8
                    Those tests with the resistor jumpers in place? If so, bad PSU is likely the cause.
                    Quick question: Should we be testing the VA and VS with the resistor jumpers in place when we remove the boards? I get basically no reading with everything attached. However, when I disconnect the z-sus from the power supply or disconnect the Y-sus from the z-sus I get about the right numbers if I immediately test, but I can watch the values rapidly diminishing. Tests are with a digital voltmeter at 200V.
                    Any ideas anyone? Power supply?
                    • easternversant
                      • Dec 2015
                      • 8
                      Also, I know that this is a bit of thread necromancy...
                      • woodgeek
                        • Jul 2013
                        • 5
                        I'm about to dive into a repair of my LG 50PA5500. This thread helps a lot but I was wondering if there is a master service document somewhere that documents all of these steps with a flowchart or something? My symptoms are: when plugged in, the relay on my TV clicks and then the red LED on the power supply board glows. Nothing after that.
                        I've got a repair kit, EAY62609701, that I ordered from ShopJimmy.com, that will replace any typical failed components.
                        • divingfe
                          LG Plasma 50PA5500. Sound, no picture !!
                          by divingfe
                          Sorry if this is too repetitive, or in the wrong place.
                          I'm new, and having much the same problem. My LG50PA5500 TV has been working flawlessly since new. The other day, while in the midst of watching a broadcast DTV channel, the entire screen suddenly and silently went dark (no snaps, crackles or pops); sound, channel selection and inputs all work OK.
                          I have checked connections and voltages from: stdby, pwr supply board fuses, psb output voltages to Zsus board and its fuse, output voltages from Zsus to Ysus and its fuse. All precisely normal!! I've also checked voltages to the...
                          06-19-2021, 06:36 PM
                        • Alain Renteria
                          LG OLED77G2PUA Not Powering On After Storm
                          by Alain Renteria
                          Got it for free on marketplace because it stopped working after a storm.
                          When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
                          The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
                          Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
                          11-25-2024, 11:11 PM
                        • ArMaaN376
                          Samsung PS51E550 Plasma TV
                          by ArMaaN376
                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                          Opened TV cover & observed foll
                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                          How to confirm Y -Buffer board...
                          06-19-2024, 04:05 AM
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
                        • KYBOSH
                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                          by KYBOSH
                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                          No picture but you hear the TV static (white noise) playing loud and clear.
                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                          But it seems they didn't get too far and just left it.
                          When I first took a look I was amazed at how pristine the inside looked.
                          Its as if the TV had been in a time capsule.
                          Caps looked like they were just pulled off the self.
                          Copper coils had no sign of corrosion on...
                          02-01-2023, 11:10 PM
