p50hdtv10a Plasma snow and lines good sound
  • ntehicks
    • Mar 2011
    • 272
    I have a p50hdtv10a vizio plasma tv that my neighbor brought over to see if I could figure out what is wrong with it. I am not sure where to start. so I thought I would test the upper and lower buffers to see if any of them are shorted. I will add a picture of what the screen looks like
  • ntehicks
    • Mar 2011
    • 272
    Re: p50hdtv10a Plasma snow and lines good sound
    I tested the buffers as Coppell tv has posted the upper buffer is 395 and the other direction is infinate. the lower buffer is 76 and 59 which I would think is bad. can I replace the bottom one or do I need to check the y board for problems.
    • capkid
      • Oct 2010
      • 1339
      I'd verify that you're getting the proper voltages from the Y-Sus just as a sanity check, but it sounds like your lower buffer is bad. What is the part number of the buffer? The reason I ask about the part number is that it could be that one of the buffer's mosfets has failed, in which case you could just replace the mosfet.
      LG Plasma Mal-Discharge Correction Service
      • ntehicks
        • Mar 2011
        • 272
        the part number on the board is 6870QDC105A
        it is a LGE PDP 050805
        Board YDRV_BTM
        model 50X3
        • capkid
          • Oct 2010
          • 1339
          Ok, yes, you've probably seen Coppell's blog, and they mention that a FET on the buffer could be causing your issue. Have you tested any of the FETs? I had an LG-based TV with an identical chassis, and the lower buffer had a bad FET that caused vertical lines on the screen. Also, closely visually scan your buffer chips for pin-sized holes.
          http://blog.coppelltvrepair.com/2010...-lines-in.html
          Edit: If you choose to just replace the buffer, it looks like there's a substitute if you can't find the original at a decent price: http://www.shopjimmy.com/lg-6871qdh089a-ydrvbt.htm
          • ntehicks
            • Mar 2011
            • 272
            I tested the FET's on the bottom buffer part number FQB46N15 and they were testing bad. I removed all three of them off of the board and tested. just one is testing bad. I purchased a set of 3 FET's and replaced all three of them. the board tests good now. I installed the buffer and now the tv works perfect. thanks so much for your help.
            • capkid
              • Oct 2010
              • 1339
              Good to hear.
              • ntehicks
                • Mar 2011
                • 272
                I ran the tv for an hour and figured it was all fixed. now the tv is blanking out. could this be a voltage issue.
                  When it blanks out, can you still see a glow from the screen or does it go black completely?
                  • ntehicks
                    • Mar 2011
                    • 272
                    it goes completely black
                      OK, check the Vs voltage coming out of the power supply before and after it goes blank.
                      • ntehicks
                        • Mar 2011
                        • 272
                        so during the day the tv would flash on and off and now the tv won't turn on at all. I will go and check the VS voltage as well as the others.
                        • arctor
                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                          by arctor
                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                          04-26-2025, 05:22 AM
                        • ChaosLegionnaire
                          by ChaosLegionnaire
                          09-13-2022, 09:02 AM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • LEECH666
                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                          by LEECH666
                          Good day ladies and gentleman!
                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                          01-19-2024, 05:46 PM
                        • KYBOSH
                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                          by KYBOSH
                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                          No picture but you hear the TV static (white noise) playing loud and clear.
                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                          But it seems they didn't get too far and just left it.
                          When I first took a look I was amazed at how pristine the inside looked.
                          Its as if the TV had been in a time capsule.
                          Caps looked like they were just pulled off the self.
                          Copper coils had no sign of corrosion on...
                          02-01-2023, 11:10 PM
