Philips 23PFL5522D/12 PSU problems
  • sparkydz
    • Jun 2013
    • 19
    • France
    Hi there,
    My Philips TV (23PFL5522D/12, chassis LC7.2E LB) has just packed in again. PSU makes a ticking noise even standalone outside ot the TV. It's my own fault - although I ordered a full set of caps (or almost), I decided that the less soldering I did, the less chance there was of messing things up. BAD DECISION! OK, this time I've changed the rest in the bad-boys corner, but noticed that one of the SMD zeners was fried. I've desoldered it, but don't know what it's value was. I checked the SM I got from Elektrotanya for this chassis, but the PSU doesn't match. Photos of my kit below. My questions:
    1. What is the value of zener ZD203? and can I use a radial one for easier soldering?
    2. The original caps were CapXon GF and GL series which I replaced with Panasonic FM/FK series. Is this OK?
    3. I've only replaced the caps on the far right of the photo (surrounded by a heat sink. I guess I should change the others too (excepting the large Rubycon), but one of them was siliconed to the board and its value unreadable. It's at the top, more or less in the middle in the photo (and looking a bit of a mess where I've tried to scrape away the silicone), is a 50V and labelled C23 on the board. Anyone know what its value is? I could desolder it and measure the capacitance, but that would assume it's OK.
    Thanks for any help you can give me!
  • sparkydz
    • Jun 2013
    • 19
    • France
    Re: Philips 23PFL5522D/12 PSU problems
    Hello again,
    I've still not got managed to sort things out, but have a couple of ideas:
    - Not sure about my FK series Panasonic caps. Are these ESR, or should I replace them with FM or FR series?
    - The zener has a wide red band, a narrow red band and a narrow green band. Looking it up on the web suggests 15V, but it's on the end of the 5v supply circuit. What appears to be an identical circuit next to it gives 5.80 -5.92V when powered up ... so it must be ~5.8V zener, right?
    Can anyone help me out?
    Mike
      Is the band (Catohde) side connected to the +5V power supply out put and the Anode side is connected to ground? If it is, it is just a safety clamping Zener Diode in case the +5V loses its regulation, the Zener will scarifies itself and shorted out, the Zener voltage is usually 6.2V 1/2W.
      • sparkydz
        • Jun 2013
        • 19
        • France
        Thanks for your quick reply!
        Yep, that's it, but there's something odd with the measured voltages.
        - The dead zener was between "Gnd-audio" and "-Vaudio", but I get a constant 0V across it.
        - The other (still ok?) zener is between "Gnd-audio" and "+Vaudio", and here the voltage switches between 0V and about 5.8V with every ticking noise. What might be causing this? Could it be the FK series caps aren't low ESR? Or something's toast further upstream?
        -- Mike
        • sparkydz
          • Jun 2013
          • 19
          • France
          A bit more info - I think audio voltages should probably be + and - 12V, so I don't know why I'm only getting 5.8V.
            for 23" TV I will doubt very much that they will use bi-polar (+/-) power supply for the audio (typical op-amp uses +/- PS).
            You may have to try to locate the service manual for this TV.
            • sparkydz
              • Jun 2013
              • 19
              • France
              Hmmm, got the service manual from ElektroTanya, but the 2 versions of PSU are _nothing_ like mine, so it's pretty unusable. I tried Philips and Delta, but both were (as expected) unhelpful. I'll see if I can guess what the PSU gives by looking at what the other boards use...
              • mr2013e
                Elc. Engineer
                • Jul 2013
                • 41
                • TURKEY
                i think zd203 and zd202 same diode.
                • sparkydz
                  • Jun 2013
                  • 19
                  • France
                  Just noticed a bit of text half hidden by a heatsink - see blurry photo. Looks like the audio is bipolar and 12V after all, so the zeners are 15V. I guess the 'good' one just isn't getting enough time to get up to 12V before the 'bzzzzzz-tick' shutdown.
                  When I recapped, most of my new caps were Panasonic FM, but some were FK. My guess is that the FKs are not low enough ESR. Will change for FM or FR and post my results. Fingers crossed...
                  -- Mike
                    Wow, this is the first time I see TV power supply with +/- 12VDC outputs.
                    • mr2013e
                      Elc. Engineer
                      • Jul 2013
                      • 41
                      • TURKEY
                      so you can measure +-12volts on zd202 and zd203.???
                      • sparkydz
                        • Jun 2013
                        • 19
                        • France
                        Can't measure much yet : zd203 is dead and has been removed, and as I said earlier I only get up to about 5.9V on zd202 before the PSU shuts off and retries. I'll retest and report on my findings when recapped and (hopefully) working.
                        -- Mike
                        • mr2013e
                          Elc. Engineer
                          • Jul 2013
                          • 41
                          • TURKEY
                          are you sure this output of power supply is for sound.(zd202 zd203)
                          • sparkydz
                            • Jun 2013
                            • 19
                            • France
                            Yep, it supplies the -Vaudio and +Vaudio pins (I think I said this before).
                            -- Mike
                            • mr2013e
                              Elc. Engineer
                              • Jul 2013
                              • 41
                              • TURKEY
                              then remove -+12v socket in power board and measure volts on zd202 and zd203
                              • sparkydz
                                • Jun 2013
                                • 19
                                • France
                                That's what I've been doing - the PSU is completely disconnected from the rest of the TV. Only the 230V supply is connected.
                                -- Mike
                                • mr2013e
                                  Elc. Engineer
                                  • Jul 2013
                                  • 41
                                  • TURKEY
                                  then recap with PANASONIC .and use 12volt zener for zd203.
                                  • sparkydz
                                    • Jun 2013
                                    • 19
                                    • France
                                    Can anyone tell me if the Panasonic FK caps are likely to be causing me problems (related to ESR)? I can try replacing them again with FM or FR series, but it would be nice to know if it's worth trying. And for the smaller caps that don't exist in FM/FR (eg 1uF) what should I use? FC?
                                      FK should be fine.1uf does not have to be low ESR, but should be 105C rating.
                                      • mr2013e
                                        Elc. Engineer
                                        • Jul 2013
                                        • 41
                                        • TURKEY
                                        panasonic caps have so much life time under stress.good quality indeed
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • nev1001
                                          What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                          by nev1001
                                          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                          I think an issue could be a zener diode (or capacitor) which has shorted out.
                                          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                          04-17-2025, 05:09 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
