32mf231d/37
  • aaronwt6
    • Apr 2013
    • 855
    • US
    32mf231d/37
    Just picked this up after work and I can't for the life of me figure out how to get the back cover off. I know it has plastic tabs in addition to the screws but I fell like I'm going to break it prying on the edges. Any suggestions from someone that has taken one apart before? There is a little slot on the back with a lock symbol too and I was thinking that might have something to do with it. Can't find good instructions anywhere online.
    Meant to put Magnavox in the title but I can't edit now.
    Thanks,
    Aaron
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: 32mf231d/37
    Scratch that guys. I wasn't using enough force. :-) Got the back off and the power supply has 3 bad caps. Explains the shutting off after 10 minutes or so of watching.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Re: 32mf231d/37
      Pictures of the power supply.
      • notallbad
        • Oct 2012
        • 1190
        Re: 32mf231d/37
        Those caps certainly need swapping out, but is that all it needed?
        Ker-ching$$$$$$$$$
        • capkid
          • Oct 2010
          • 1339
          Re: 32mf231d/37
          I worked on one of these awhile back, and I had to replace two 1200 mfd caps to get it working. That was the extent of the damage; nothing else had failed. In your case, you obviously have three bad caps to replace.
          LG Plasma Mal-Discharge Correction Service
            Re: 32mf231d/37
            If you're curious, run the set with the caps bad. Measure the power supply voltages. Chances are you'll find the 5V rail dropping as the set begins operating, causing the main board to shut down after a short period of time.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Re: 32mf231d/37
              Working perfect for the last hour. $25 for the TV and 3 caps. Nice picture for a 7 year old TV too.
              And Tom, the voltage was indeed dropping at multiple locations. Once it approached 4v that's all she wrote.
              • capkid
                • Oct 2010
                • 1339
                Re: 32mf231d/37
                Cool. Do you have a buzzing sound at all? After I fixed mine, the buzzing sound was annoying.
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  Re: 32mf231d/37
                  Nope. No sound other than the speakers. :-)
                  Wonder what the buzzing was on yours. Audio, or something coming from the board?
                  • capkid
                    • Oct 2010
                    • 1339
                    Re: 32mf231d/37
                    Hmm. I wonder if the 2200 mfd cap was failing in my TV, also.
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      Re: 32mf231d/37
                      Well crap. It started back after about 90 minutes. Resets every 10-15 seconds. Back to the drawing board. Unfortunately I put it all back together.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: 32mf231d/37
                        If you only replaced the obviously bloated caps, don't be surprised that you might have more bad caps unless you have an ESR meter and tested each capacitor out of circuit. Think cockroach theory.
                        --- begin sig file ---
                        --- end sig file ---
                        • aaronwt6
                          • Apr 2013
                          • 855
                          • US
                          Re: 32mf231d/37
                          Yeah. I realize maybe some others were bad as well. The kit I bought came with all 15 or so that are on the board. This weekend, I'll take it back apart and swap all of them. I just figured I'd take the easy way out and save the others for a rainy day. Will update when the rest are swapped.
                          The only one I don't have is the large main capacitor so hopefully it's not the problem.
                          • truep
                            • Aug 2010
                            • 373
                            Re: 32mf231d/37
                            The big one rarely fails.
                            • aaronwt6
                              • Apr 2013
                              • 855
                              • US
                              Re: 32mf231d/37
                              Thanks. That was my understanding from much of the reading I've done here. I'll post results once the others are changed.
                              • aaronwt6
                                • Apr 2013
                                • 855
                                • US
                                Re: 32mf231d/37
                                Changed the remainder of the caps and the set is working perfect now. Ran it through 2 full movies last night with no restarts so I'm calling it good.
                                Thanks for the help / recommendations.
                                Aaron
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Re: 32mf231d/37
                                  You bought a kit? Hopefulley they a good brand of capacitors.
                                  Muh-soggy-knee
                                  • aaronwt6
                                    • Apr 2013
                                    • 855
                                    • US
                                    Re: 32mf231d/37
                                    Yes. Rubycon. Everything worked great.
                                      Re: 32mf231d/37
                                      What series Rubycon e.g. ZL, YXF...?
                                      • aaronwt6
                                        • Apr 2013
                                        • 855
                                        • US
                                        Re: 32mf231d/37
                                        Well Tom. That's an excellent question which I can't answer now. I already re-assembled everything. What should I look for in the future?
                                        I believe they were gold and black in color. Not sure if that's specific to Rubycon or if it represents the series. I do know that they had a 105 degree temp rating.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
