Mosfet replacement
  • shorteddiode
    • 221
    Mosfet replacement
    I hope I didn't post this in the wrong spot
    Does anyone know of a replacement for a STTH20P03S Mosfet?
    Out of a Samsung Z board. I can't find a data sheet on it
    Re: Mosfet replacement
    200V, 3A device, I believe.
    • shorteddiode
      • 221
      Thanks tom, any idea where I can find a data sheet for it?
      • tw2005
        • Oct 2011
        • 6458
        I think the important thing to note here is it's in fact a fast recovery diode, common cathode.
        Pins 1-3 will test short in cct, A-K-A , centre pin is cathode.
        Datasheet I found does not match the number exactly
        • tw2005
          • Oct 2011
          • 6458
          300v, 20a diode
          • shorteddiode
            • 221
            Thanks everyone.
            • junkyardherbie
              • Sep 2017
              • 7
              When you say in cct, do you mean with the component installed in circuit? Or do you mean in a circuit continuity test with the component out of circuit? Sorry I'm not sure what your abbreviation means... I know this is an old thread but I have this same exact rectifier and pins A1 and A2 measure continuity with no resistance between them (shorted) with the component out of circuit. I am understanding this as a failure? Thanks to all in advance.
              • tw2005
                • Oct 2011
                • 6458
                two anodes , 1 cathode. A1, A2 are 2 anodes.
                anode to anode = short it's the same reference point = normal
                Anode to cathode in diode will be 0 one way and whatever voltage drop the other. Could be 0.3- 0.5 as long as it's not shorted both directions it's ok.
                In or out will be the same. Now if the whole this was shorted then you'd remove and retest because other things connected could be shorted but the diode is ok.
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  in laymans terms, there is a diode between the outer pins and the centre pin, but both outer pins are tied together, so it is shorted out of circuit. this is how it should read, there fore, it is good. if you have continuity between either of the outer pins and the centre pin, then it is bad.
                  tw beat me to it, :P
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  • junkyardherbie
                    • Sep 2017
                    • 7
                    Thank you all! I have continuity between A1 and A2, and .378 between A1 and K with + to anode and - to cathode, nothing with leads reversed. Same result from A2 to K. From your teachings this means it's good... I appreciate the help. I didn't realize the anodes were tied together, I thought they were separated by their respective diodes... on to further testing!
                    • the_rem
                      Unknown transformer : how to find a good replacement part ?
                      by the_rem
                      Hello guys,
                      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                      04-23-2025, 01:48 AM
                    • jm942
                      Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                      by jm942
                      My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                      I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                      I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                      I did voltage injection on the cpu with 0.7V and i have a current...
                      07-11-2024, 05:11 AM
                    • samoelec
                      Trying to understand how to find best replacement cap for old parts.
                      by samoelec
                      Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
                      Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
                      The power supply board is exactly the same from this post so I'll just steal it for now.
                      I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
                      04-01-2024, 03:39 AM
                    • Jane
                      How do you test MOSFET in laptops ?
                      by Jane
                      I tried to use this method:
                      Testing an N-channel MOSFET:
                      Step 1: Discharge the Gate (turn off the MOSFET)
                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                      Step 2: Charge the Gate (turn on the MOSFET)
                      Now, place the red probe on the Gate (G) and the black probe on the
                      09-27-2024, 03:31 AM
                    • Oliver111
                      Asus UX535L.Help to find name of mosfet driver
                      by Oliver111
                      Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google....
                      04-08-2024, 07:47 AM
