LCD TV cooling Fan possible ?
  • Sevenqi
    • Jul 2011
    • 292
    I repaired a 32" LG LCD TV, the backlight was off about 10 minutes watching, but sound was still good. I thought it should be the backlight inverter or CCFL lamps problem, but when I took out the panel and check all the lamps are in very good condition, the inverter transformers are not shorted.
    So I turn on the TV without put back the cover, it's one hour and it still working, When I touched the mental holding the lamps, it's very hot, the heat was from the lamps, so I think the backlight off is because of overheat.
    I'm think to add a fan on the back near the power supply, but I need to control the fan's on/off, I would like to use a 12v fan and connec to the 12V output from the power supply, I'm afraid if this is good idea to add more loads to the power supply?
    May be someone in this forum did this before, please advice.
    Re: LCD TV cooling Fan possible ?
    I would expect all you are doing is delaying the inevitable.
    The TV is probably overheating but this is only because it has been damaged by this heat over time. As it gets hotter it fails. But it didn't originally. In a year's time it might cut out in a minute instead. You really need to find and replace the failing parts.
    I can't see how adding a fan to the set is going to overload the power supply.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • Yanleb
      UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
      by Yanleb
      My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
      Disconnecting the main board from the power supply makes the backlight come ON.
      I did disconnect the panel cables and the WIFI modules, the board is still dead.
      I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
      Thanks.
      11-18-2024, 12:34 AM
      07-01-2024, 06:34 AM
      by momaka
      03-15-2023, 10:17 PM
