Pioneer PDP-4270HD
  • mcross
    • Sep 2011
    • 201
    Pioneer PDP-4270HD
    I have a Pioneer PDP-4270HD, power light is on standby light is on, get no response when power button is pressed. Seem to have correct power from the ps. Any ideas as to where to look for the problem.
    Mike
  • mardocdor
    • Jun 2013
    • 31
    • philippines
    Re: Pioneer PDP-4270HD
    Hi! Did you try turning it on using its remote control? If it wont work, try to measure the voltage on the PSU if it present and normal...
    • mcross
      • Sep 2011
      • 201
      PSU voltage is normal, I do not have the remote. checked the button switches, all good
      Mike
      • mcross
        • Sep 2011
        • 201
        I have been looking at this again and both the standby and power on lights come on when the cord is pluged in. ///? strange?
        • cliff_hootarski
          • Jul 2006
          • 411
          Does this model incorporate a 'trap" switch? It looks as if it does on the right support column. If you power on the set without depressing the switch, the TV goes into a shutdown mode.
          • mcross
            • Sep 2011
            • 201
            I seen that and checked it but no help. I will keep looking
            thanks
            Mike
              If you trigger the trap switch you need to reset it. There are instructions in the service manual.
              • mcross
                • Sep 2011
                • 201
                Ok, that's new for me. Will look at that. Just thought it needed be depressed
                Thanks Tom
                • cliff_hootarski
                  • Jul 2006
                  • 411
                  If you would have read the pdf file I supplied in my previous post, you would have seen the symptoms of both the power and stby LED's is the trap switch protection feature has been triggered.
                  • mcross
                    • Sep 2011
                    • 201
                    Sorry Cliff, I looked at the pdf, but not the trap switch, first time seeing one of them
                    mike
                    • cliff_hootarski
                      • Jul 2006
                      • 411
                      I have a 50" model (5045HD) that would not turn on. I unplugged one or both sustain boards and tried to turn it on. That must have reset something because all I had to do then was to clear the trap switch problem and have been watching the TV ever since.
                      • Andreasbest
                        Dell Latitude 7410 dead and amber light as long power button is pressed.
                        by Andreasbest
                        Hello.
                        I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                        Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                        Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                        Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                        12-21-2024, 02:02 PM
                      • zwect
                        Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                        by zwect
                        I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                        Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                        Here is the original BIOS dump from the 25R256JVEN chip.
                        09-11-2024, 05:54 PM
                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                        by sam_sam_sam
                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                        I also have back when Light of America had these light bulbs available for yard lights
                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                        While the Lithonia lighting fixture has all most certain bulb failure
                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                        I have only had this light fixture for not more than a year if it...
                        07-02-2023, 03:45 PM
                        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 03:40 AM
                        LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 09:10 PM
