Sony KDL-40S504 6 blinks
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-40S504 6 blinks
    What happens if you reduce all those settings where is the Gamma?
    They are all on high setting.
    It can't be a weak ccfl tube? If I understood correctly, when the tubes are getting weak, they show a pinkish screen, no?
      Gamma is t-con only, used to linearise display brightness.
      Weak CCFL cause 2-secs to black or pink tint, but that wouldn't be so obvious here. This is clearly some formatting/mode error IMO.
      • kevinm34232
        • May 2012
        • 1884
        I dont think so that's the only firmware I found on their site unless they have them archived somewhere else..
        • kevinm34232
          • May 2012
          • 1884
          The best Ive been able to tell is the T-Con and main board are correct parts for the panel. The only thing that spiked my curiousity is when I took the T-Con out, it had a "V" marking on the back of the board which I have seen when purchasing some boards on ebay from a certain seller. So maybe this board is the wrong one or even faulty.
          If anyone is familiar with these here are the parts I have:
          Panel: LTY400HA12
          T-Con: Samsung LJ94-02814D
          I can't be sure but it doesn't look like anyone had been inside this TV before...
          • kevinm34232
            • May 2012
            • 1884
            I found this video on how to bypass a bad bulb on this type of backlight setup
            https://www.youtube.com/watch?v=oE6K4xBVweA
            and it worked for the 2 seconds to black, but now it has a 10 seconds to black. The LD line stays high (around 11V) on and through startup, then goes low after about 10 seconds, there's probably more bad bulbs.
            I really don't wanna dive into the panel knowing I have this other weird video problem too...
            • kevinm34232
              • May 2012
              • 1884
              So I got around to replacing 2 bad CCFL bulbs in this TV, and the backlight issue is fixed. Now the weird color issue.
              Anyone know how to get into the factory menu on this model?
              • kevinm34232
                • May 2012
                • 1884
                Got to this menu but was hoping to get to a menu where you can see the panel type..
                • kevinm34232
                  • May 2012
                  • 1884
                  Is this most likely a main board issue Im not gonna be able to fix, or possible T-Con?
                    Main board. The format is wrong but I do not think it can be changed on these sets, without replacing the main board.
                    • kevinm34232
                      • May 2012
                      • 1884
                      I wish I can find an older firmware as Im not sure it was like this before I upgraded it. Is there a site that archives firmwares?
                        You may try asking Sony nicely, though I don't expect a good response.
                        • kevinm34232
                          • May 2012
                          • 1884
                          Replaced main board on this one and that fixed color issue, thanks Tom.
                          Double whammy on this one, 2 bad bulbs and a bad main board.
                            More likely, user or service tech attempted replacement of main board without matching up part numbers.
                            • kevinm34232
                              • May 2012
                              • 1884
                              I ordered the same part # that was in there though, so Im thinking maybe the firmware screwed it up but not sure...
                              • matwan
                                Sony XR-55X90J 5 blinks
                                by matwan
                                I have problem with SONY 55X90J. After several check status is as below;
                                1. Running power board as stand alone:
                                TCON_12V =~ 12.6V
                                EVDD V On Max 24V= 19V.
                                2.
                                Running power board with TCON as stand alone:
                                Effect as below, attched.
                                3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                Best regards....
                                09-28-2025, 04:26 AM
                              • GoodCapDude
                                Sony XBR-75X940E intermittent 6 blinks error code
                                by GoodCapDude
                                Hi everyone. First post on Badcaps!
                                I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                09-20-2025, 06:07 AM
                              • odie34
                                Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                by odie34
                                I am a hobbyist (not a professional) so please be gentle...
                                I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                02-18-2024, 09:11 AM
                              • reassor
                                Sony kd70xf8305 very very slow android logo with sound
                                by reassor
                                Hi.
                                Power is ok
                                Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                                Should i force update? If so how?
                                I did reset.
                                Mainboard Looks pristine.
                                Very wierd.
                                10-30-2023, 05:59 AM
                              • Ihandyrepair
                                4 red flash led 65X950G boot Sony and android logo but then black
                                by Ihandyrepair
                                HI guys
                                I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                here is the issue
                                I have Sony and android logo. but then 4 led red flash lights front of the tv
                                I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                but then I get black screen and 4 red flash light at the front LED
                                but I get 3 led flash on the LED driver board.
                                I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                so I tried...
                                07-11-2024, 01:45 AM
