samsung 42" LCD lines after bad caps replaced LE40A456C2D
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    Hi folks, I picked up a samsung LE40A456C2D stuck in standby , I replaced the 4 bulging caps on the board marked in the picture , the set now boots up but i have lines on the screen (see video) , Ive been told this maybe just ribbon cable that has burned since over voltage with the bad caps but i cant see any problems with the cables.
    If i move the set or apply a little pressure around the top of the inverter board the screen changes but the lines never go fully away.
    http://www.youtube.com/watch?v=Tdihh...ature=youtu.be
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    Re: samsung 42" LCD lines after bad caps replaced LE40A456C2D
    Uploaded with *************
    • notallbad
      • Oct 2012
      • 1190
      Might be better to have a source input connected to show the full extent of the image defect.
      Most likely bad tab bond, buffer or t-con.
      • karlpowell
        badcaps.net
        • Feb 2013
        • 104
        OK ill get some more pics now ...1 min
        • karlpowell
          badcaps.net
          • Feb 2013
          • 104
          these pic are all of the top right hand side of the screen
          • karlpowell
            badcaps.net
            • Feb 2013
            • 104
            The owner assures me the screen did not have this fault untill the caps failed .
            • johnboy1313
              • Nov 2012
              • 1959
              The last set I bought, the owner assured me that it worked intemittently and that he never opened it up. It's missing the LVDS cable. People lie. That doesn't mean your guy lied to you, but it does happen.
              • notallbad
                • Oct 2012
                • 1190
                Very true!
                It can lead you on a wild goose chase believing what the seller/original owner tells you, either because they want to get more for it or don't want to own up to doing something that they shouldn't have!
                A picture of the whole view of the tv screen please, its to see the overall picture distortion not just a specific area. If its a good quality picture we can zoom and pan without loosing too much picture quality.
                • Clydeuk
                  • Jan 2012
                  • 193
                  Afraid your panel is defective, these are single pixel lines which narrows it down directly to the drive ic or tab bond connection (panel side). Most likely the IC associated with that area (there appear to be 2 areas as well)
                  I doubt a bad power supply could cause this damage, I would suspect the person who sold this to you either:
                  Put up with this until the power supply failed. or
                  Bought this like this as a donor set, power supply pulled to fix another, old PSU fitted and sold as non working.
                  Sorry I know that's really negative but I've encountered this a few times.
                  • karlpowell
                    badcaps.net
                    • Feb 2013
                    • 104
                    • karlpowell
                      badcaps.net
                      • Feb 2013
                      • 104
                      I have another Samsung and the picture is a lot better on that than this , it can look a little washed out sometimes
                        Panel's definitely bad.
                        Very common on these models.
                        If it was simply a loose tab bond you would have only dark or only lit up lines, but you have both. So the driver is defective.
                        It looks like cheap CHIMEI or CHUNGWHA panel, not very nice to watch. Proper Samsung use a SAMSUNG panel like LE40A656 which looks quite nice, though still doesn't quite look as nice as a good plasma...
                        • karlpowell
                          badcaps.net
                          • Feb 2013
                          • 104
                          thanks Tom and everyone else who has replied.
                          • Clydeuk
                            • Jan 2012
                            • 193
                            I had a BEKO set with similar issues, when I dismantled the panel assembly to look at the tabs (out of curiosity) I discovered a couple were kinked (like a crinkle on the flexible print). Sure enough applying gentle pressure at the right place could cause some of these lines to disappear, or sometimes confuse the T-CON enough to crash the whole display. I believe that was a CMO panel as well. Think it's bad assembly at the factory that causes this to occur, and I don't believe it's particular to any manufacturer as Samsung panels themselves can suffer this problem. The fact is there are an awful lot of very miniscule traces on each tab to drive each column of each subpixel across the width of the display, doesn't take much to cause a problem here.
                              09-07-2024, 05:50 AM
                              by momaka
                              03-12-2025, 03:42 PM
                            • Rubenlily
                              Samsung QE50Q67TAU - horizontal lines
                              by Rubenlily
                              First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                              I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                              I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                              I'm no expert but I've done the tape...
                              08-16-2023, 01:12 PM
                            • howardc64
                              by howardc64
                              Yesterday, 05:17 PM
                            • jeyoung12
                              Samsung QN50Q60t lines on screen
                              by jeyoung12
                              Hi all
                              I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                              My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                              This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                              It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                              So....i don't know what end of the C ribbon to work with...
                              02-26-2024, 10:38 AM
