So im about to replace 2 resistors on my LG...question...
  • joyride
    • Apr 2013
    • 39
    Im about to replace 2 resistors on my LG 50PJ350 's PSU
    Here is the kit that im using:
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Now does it matter what solder I use for this? This kit came with some sort of lead-free...im guessing standard electrical solder
    any advice for a noob would be appreciated
  • mariushm
    • May 2011
    • 3799
    Re: So im about to replace 2 resistors on my LG...question...
    It doesn't matter.
    The old solder on the board is lead free.
    If you plan to use leaded solder (easier to work with, with that iron), just do your best to clean the old solder from the board but don't stress yourself too much.
    If you mix lead free and leaded solder there might be an issue of reliability (weaker soldering job) but we're talking about possibility of failing in years of use.
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • Tarot Superstars
      What LED's to Buy To Replace Backlight LED's and What Solder with LED's
      by Tarot Superstars
      Hello.
      I changed the led strips on my Hitachi 32 inch.
      The TV is now ok since I have already replaced any capacitors that needed replacing.
      I have also bought a spare set of LED strips for the tv also.
      I want to be able to replace singular LED's in the LED strips if I need to, but I am not sure what value LED package to buy from Ebay in the UK.
      The LED strips I bought were:
      Replacement Backlight Array LED Strip Bar For Hitachi 32HB6J61U 32HBT41U 32" TV
      On ebay I have a choice of singular LED's with voltage and...
      09-02-2023, 02:44 PM
    • TinkerTron
      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
      by TinkerTron
      Hey everyone,
      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
      Instead, here's what's been bugging me so far:
      The schematic...
      03-06-2025, 02:03 PM
    • corrize
      Best way to solder LVDS connector for beginner (and qfn) ?
      by corrize
      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
      See the test :
      https://youtu.be/bNAzC-EvqHs?t=1767
      With hot air from bellow the board, that's...
      03-09-2023, 02:57 AM
    • petemanuk
      BGA solder balls not connecting - help pls
      by petemanuk
      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
      11-16-2022, 05:21 AM
