Philips BDS4231R/00 PDP S423D-YD07
+ More Options
Posts
  • notallbad
    • Oct 2012
    • 1190
    Re: Philips BDS4231R/00 PDP S423D-YD07
    Any idea what the I.C U4002 is on the x-main?
    Where might I find a schematic for this board?
    I think I shall have a go at repairing the board and see if the tv is salvageable.
      Gate driver for the FETs, so a FET is probably short, and some other components are likely bad too.
      No schematic for Samsung X-main unless you break into their headquarters and pull of a daring heist.
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • janos6662000
        Philips 47PFS7509/12 LCD TV problem
        by janos6662000
        Hi
        I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
        When i applied cable signal to check image, i had normal picture, but TV was restarting.
        I downloaded original firmware and applied the update, but the problem remained.
        From a colleague i received a "factory package software" which is a lot bigger.
        I made another firmware update, but still did not solve the problem.
        Somewhere on the way the error got worse, because at the moment the...
        08-12-2025, 12:54 PM
      • aidanmo
        Philips 43PUS7506/12 - Loud blown out sound
        by aidanmo
        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
        I thought maybe the speakers got damaged, so I replaced them - no dice.
        • Using the internal speakers, it always happens.
        • Using the headphone jack, it never happens.
        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
        02-28-2025, 03:13 PM
      • Cornito
        Philips 50PUH6400 bad color and gosting / slow motion on one side
        by Cornito
        Hello Team,
        New issue on LCD panel where I need to find out the cause and the potential solution.
        This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
        I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
        When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
        I've checked voltages, no issue found comparing right and left side of the panel driver.
        VHG VGL CKV... are the sames on...
        03-08-2024, 06:41 AM
      • spantor
        Activate power board Philips 40PFH40009/88 tv
        by spantor
        Hello partners.
        Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
        The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
        02-11-2024, 05:07 PM
