Philips 47PFL7422D - Dim on left side (different than other thread)
  • DLinkOZ
    • May 2013
    • 238
    I have a 47" Philips - 47PFL7422D. It would turn on and within a minute go extremely dim and flicker. Found both caps in both inverters (master and slave) were popped, so I replaced all four of them this morning. Powerd up and things are a bit strange:
    It was bright as it should be on the right side, still dim on the left. After a few minutes, the right side went dim but there was no flicker. I unplugged the left (from the front, slave) output to the CCFL and the right side went back to a normal brightness. It has enough light output to actually light the left quite well on its own. I've let it play off the DVR for many hours now, and it's been solid.
    I went back just recently, and plugged the left (slave) side back in (output to CCFL). Entire panel immediately went dim. Unplugged and it returned to how it was (right bright, left dim). Any ideas what would cause this behavior?
    Re: Philips 47PFL7422D - Dim on left side (different than other thread)
    If you look at the rear of the chassis in a dark room, you should see several holes which glow when the TV is running. Is the slave side noticeably dimmer than the master?
    • DLinkOZ
      • May 2013
      • 238
      Well, it's dimmer in the holes now because the slave is disconnected and the master side light is bleeding over (that's the extent of lighting on the slave side). If I connect the slave side, the master side goes quite a bit dimmer. Or did I misunderstand your question?
        No, you didn't misunderstand me. I misread your post and missed that.
        Do you have a digital voltmeter / multimeter?
        Where did you source the replacement caps from?
        • DLinkOZ
          • May 2013
          • 238
          I do have a meter, yes. The caps came from a local electronics supply store.
            Local electronics supply store is usually a big indicator of non-low-ESR capacitors which the inverters require to function correctly. The bulged ones may have actually briefly been better! Any chance you could take a picture of these capacitors so we can get an idea of the manufacturer and series?
            We highly suggest buying caps from digikey.com or from the Badcaps.net store, as both provide the right parts, whereas typical store bought caps are not up to the job. Even if the worked first time, they would fail in short order (a year at the longest in a high stress environment.)
            • DLinkOZ
              • May 2013
              • 238
              Is there any reasonable way to test that? I can place an order, but would have a better warm fuzzy feeling if I could somehow determine that it was the likely cause. Such as, could I determine that proper voltage is being output to the ccfl?
              Now that I snap a pic of the cap, I see immediately that it's an 85 degree part (the bin was labeled 105, my fault for not checking more closely). But I can't imagine that would play directly into it with the back off and immediately upon power up. Though it could lend itself to gauging the quality of the part.
                Those capacitors are certainly not suitable. Lelon capacitors are among the worst, cheapest crap you can buy. They are 85°C rated; originals would have been around 105~130°C. The temperature rating itself doesn't factor much into performance, only life. But, almost nobody, and certainly not Lelon makes low ESR capacitors in 85°C ratings.
                What is the capacitance and voltage rating of them? We need to find you some suitable replacements.
                You can't measure the CCFL output with a conventional DMM. Typically around 1500~2000V in operation and 3000~4000V to start the tubes at high frequency (>10kHz.) Your DMM will be roasted alive.
                Without an oscilloscope there's little you can do to check how the capacitor is functioning (supply rail decoupling can't be checked), but going from your symptoms of a working TV which failed after some time and one which is constantly dim or not working, then it sounds like the only variable which has changed -- the capacitors -- is at fault.
                One thing you can verify is the 24V of the power supply and see if that is stable, as there may also be bad capacitors on that.
                • DLinkOZ
                  • May 2013
                  • 238
                  Here are the original caps
                    These:
                    http://www.digikey.com/product-detai...6CT-ND/3072276
                    will be fine. Add $2.50 postage.
                    Badcaps.net does not carry 680uF 35V unfortunately.
                    • DLinkOZ
                      • May 2013
                      • 238
                      Yeah, I noticed that when I checked (wanted to try and give back for the help). But digikey order submitted, and I'll report back after I get them installed.
                      • cashkennedy
                        • Aug 2011
                        • 668
                        When you installed the new lelon caps did you make sure to be very careful the match the capacitance, and be very careful to match the + and - pins on the caps to the markings on the board. And you need to make sure none of the solder for each pin is able to touch / should be a clear seperation between the solder clump around each pin.
                        Its very possibly if one cap was different then what the bin said it had, that it could be a completely different capacitance too.
                        I personally think you have another issue other then using the wrong type of cap, like a short on 1 inverter, possibly caused by putting in a cap backwards, although youd expect that to cause the whole inverter to blow a fuse. Have you checked the inverter fuses with your multimeter?
                        Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                        • DLinkOZ
                          • May 2013
                          • 238
                          Values are the same (except for the temp, which didn't match the bin and my fault for not validating). Also, 100% sure I got the polarity correct and did not bridge any solder joints. I did verify capacitance and voltage per cap as I soldered, so they were all the same.
                          • DLinkOZ
                            • May 2013
                            • 238
                            I'll be smurfed! The fuse is actually bad (no continuity). So the question is - does it make sense that with a blown fuse, plugging in the slave CCFL would bring down the master side? And the age-old question: is the fuse blown the problem, or a symptom (what caused the fuse to blow, same thing that caused the caps to pop or was it the caps popping)?
                            • DLinkOZ
                              • May 2013
                              • 238
                              Success! I swapped out the fuse, so lucky and random that I had another 10a ceramic on-hand. The set is now 100% lit up. I'll still change the caps when they come in, they already shipped (digi-key doesn't mess around with shipping!).
                              • DLinkOZ
                                • May 2013
                                • 238
                                New caps arrived. While installing them won't solve any immediate problems (since there aren't any at this point), they will provide longevity to the set. Again, thanks to both of you for the assistance!
                                  • 12194
                                  • U.S.
                                  having similar problem, can you tell me where the 10a ceramic fuse is located, is it on the slave board or power or main, thanks.
                                  • DLinkOZ
                                    • May 2013
                                    • 238
                                    Sorry for getting back to this so late, but it was on the slave board.
                                    • maiden790
                                      • Nov 2014
                                      • 94
                                      Where can I buy the new fuse??
                                      one mans is another ones treasure
                                      • Stephen
                                        A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                        by Stephen
                                        Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                        05-29-2025, 10:35 AM
                                      • ravi_1617
                                        HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                                        by ravi_1617
                                        Hello to all ,
                                        I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                                        Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                                        on external VGA port image is perfect /normal , Attached image...
                                        07-25-2025, 12:07 AM
                                      • Gjackson
                                        SMEG induction cooker error EA on both left hand side cooktops
                                        by Gjackson
                                        I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
                                        07-09-2024, 01:46 PM
                                      • jboxer
                                        PHILIPS 32PHS5505 side board problem
                                        by jboxer
                                        hi, im working on a Philips tv that works good, mainboard good, backlight good but the side board that control the lcd panel don't work good, in first time it only worked when I touched the board in a specific point that was very hot, I think it was a short-circuit and when I touched it my hand worked like dissipator, I had found that the source was a resistance so when I eliminate it there wasn't a short-circuit anymore but still without image only color lines when I touch the new resistance wit a metalic thing and it sparks, where can be the problem? lasts image are a close up of the board(ins't...
                                        09-02-2023, 02:46 AM
                                      • howardc64
                                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                        by howardc64
                                        • Prior owner tried a replacement main board. No difference.
                                        • Samsung 2x red blinking standby LED = panel fault
                                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                        07-19-2025, 10:54 PM
