Samsung LE40M87BDX/XEU
  • sordids999
    • May 2013
    • 2152
    hi guys
    trying to figure out this problem cant see much wrong with the power unit but i only have to plug in the tv and it blows the house main trip fuse
    any ideas ?
    Re: Samsung LE40M87BDX/XEU
    Bridge rectifier, PFC, main cap. Check all. If you want more help, you know the drill, we need pictures. Also get BN44 number off PSU and I will see if I have a schematic. I have quite a few.
    • sordids999
      • May 2013
      • 2152
      psu number is BN44-00167
        I have schematics
        http://www.toms-service-manuals.com/...&Search=Submit
        • sordids999
          • May 2013
          • 2152
          thanks for that tom ill keep for future use but i think i found the problem maybe working 12 hours on shift made me miss this
            It's not the problem, just a symptom of the failure. Have you tested the bridge recitifer, PFC fet and main capacitor yet?
            • sordids999
              • May 2013
              • 2152
              now how do i do that m8 ?
                Do you know how to test a bridge rectifier?
                It's the four-legged device, right most heatsink with danger sign on it.
                • sordids999
                  • May 2013
                  • 2152
                  i see it not sure how to test it though
                    https://www.google.co.uk/search?q=ho...hrome&ie=UTF-8
                    • sordids999
                      • May 2013
                      • 2152
                      thanks tom
                      to be fair m8 would it pay me to buy a new psu i noticed just now who ever had this tv before has changed the caps proberly bulged and it looks like they have damaged the board also
                        The PSU is not going to be cheap as it is a common failure point of these sets, I do not see sense in replacing it if the fix is relatively easy to do, but I will let you judge costs.
                        • sordids999
                          • May 2013
                          • 2152
                          from following the video im getting a reading from both connections so im guessing i have a shorted diode
                            Number the pins 1-4 as you look at the label side, where do you see a short?
                            • sordids999
                              • May 2013
                              • 2152
                              im getting readings from both directions which in the video says i should not be but 2-3 is giving me a reading of 1428 the other are giving me 500
                                Do you ever get a reading under 50?
                                • sordids999
                                  • May 2013
                                  • 2152
                                  no tom
                                    You tested the device out of circuit I'm guessing?
                                    On the PCB, using the previously described numbering scheme, test between pins 1-4 and pins 2-3.
                                    The bridge appears to be good, the fault is likely elsewhere.
                                    • sordids999
                                      • May 2013
                                      • 2152
                                      my bad im still learning
                                      1-2 is 46.8 2-3 0 3-4 47.7 so it seems its good
                                      after following the video
                                        2-3 measure "0" out of circuit?
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
