MIP320FL power supply/inverter problem
  • jones66ex
    • May 2013
    • Cuba
    saludos.
    Tengo un ETEC 32E40 com problemas en el inversor, es MIP320FL. No enciende los tubos. Necesito el esquematico, o en su defecto el la identificacion del chip PWM
    greetings.
    I have a ETEC 32E40 LCD TV with problems in the inverter, is MIP320FL. No start the tubes. I need the schematic, or alternatively the PWM chip's identification
    03-31-2024, 02:12 PM
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • ashan000
    yx-305d bench power supply decreasing voltage problem
    by ashan000
    This power supply is 30v 5amp. Problem is when turned on after about 3 minutes voltage starting to decrease slowly. (like - 5.8 > 5.7 > 5.6 > 5.5) can't see any damaged component or dry solder joints. Checked main 2 transistors with multimeter. Reading seems ok. Tried changing potentiometers(both coarse and fine) still the same situation. Can any one help me to troubleshoot? What voltages to check? Any ideas helps to fix this. thank you.!
    07-12-2025, 08:43 PM
    07-01-2024, 06:34 AM
