Panasonic Viera TC-P50G10 7 Blinking Red
    Re: Panasonic Viera TC-P50G10 7 Blinking Red
    The 5V doesn't go no where. It goes to a net marked "5V". They just didn't draw the net in. Common in electronics design. Looks like you have semi-original Panasonic engineering documents, before they were cleaned up to look nicer for the service manuals.
    • tw2005
      • Oct 2011
      • 6458
      Yeah I stumbled across it searching parts. Looks more like an original engineering drawing.
      It's been extremely useful in decoding a lot of the part numbers as they have used the same parts through a number of generations and they list both the panasonic and oem part # together which they do not in the service manuals.
        Can you upload that here so I can post it on the service manuals site?
        • tw2005
          • Oct 2011
          • 6458
          Sure thing buddy
            PX10: That's like one of the first generation of Panasonic PDPs? (2001 era)
            Panasonic were the first to demonstrate a viable large-screen PDP (read up on PlasmaCo, who Panasonic purchased), though they were beaten to commercialisation by 2 years by Fujitsu.
            • tw2005
              • Oct 2011
              • 6458
              No I've misnamed it, move the P. TH-P42X10 , SC TNPA4773 and the SS is TNPA4774.
              2009 model I believe
                Ah, well that puts it 8 years ahead of when I thought it was made... lol...
                I do have a 2001 document from Panasonic describing how a PDP works.
                but most of my other stuff is 2005 onwards.
                • riparo
                  Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                  by riparo
                  Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                  I attach a link to download the service manual, thank you for anyone who can help me
                  https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                  01-11-2024, 12:35 PM
                • mostachio
                  Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                  by mostachio
                  Hi Badcaps,
                  I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                  TV Details:
                  Model # - TH-65DX700Z
                  Symptoms:
                  The television turns on and displays a picture then makes a clicking sound and turns off.
                  I haven't opened it up yet but...
                  09-04-2024, 02:32 AM
                • Ama Chur
                  Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                  by Ama Chur
                  After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                  02-21-2025, 08:12 PM
                • badcappo
                  Dead Panasonic Viera TX-P65STW50 Plasma TV
                  by badcappo
                  Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                  Diode type G972s6 - D101 with a short
                  Mosfet 06N90E - Q301 shorted
                  Fuse T5AH 250V - F103 blown
                  Diode D301 shorted
                  Relay DG1U-17VDC II - RL001 blown
                  I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                  11-24-2024, 11:27 AM
                • CoinCoin88
                  Panasonic PF50G20S blinking 13 times
                  by CoinCoin88
                  Hello there,
                  Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
                  Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
                  06-30-2023, 05:43 AM
