E420vo
    E420vo
    Have E420VO television. I think it was struck by static from an electrical storm. Not 100 percent sure. All I know now is that it will not power up.
    My first guess was that it might be the power board, so I purchased one off of ebay. Said it was new, but I get the same thing, the vizio sign stays in the indication color for standby.
    So either the power board I received was no good or my main board is no good. I know on some television power boards there was a switch to turn the power board on manually, however I do not see that on this board. And measuring the voltages I have the +5 and that is all. So I am assuming the 12 and such comes on after the power supply turns on. So is there a way to manually turn the power supply on? So I can test it to make sure that the supply is good.
    Thanks and have a great day.
    Re: E420vo
    I had the exact same set with the exact same condition. You probably need an eeprom for the main board. Just do a google search for the board number and eeprom. You can send the board to be repaired or you can buy the chip and solder it on yourself.
    http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
      Re: E420vo
      Shopjimmy is also selling EPROM now also.
