Emerson lc407em1 Turns on screen only flashes, then off
  • proaudiosoft
    • Apr 2012
    • 68
    Re: Emerson lc407em1 Turns on screen only flashes, then off
    Originally posted by tom66
    If you get the FUNAI part number for this board (begins with BA9) I may be able to find a schematic, if you don't already have one.
    the part number is BA01P0F01 03 3
    • proaudiosoft
      • Apr 2012
      • 68
      Ok, I believe I found the service manual:
      • proaudiosoft
        • Apr 2012
        • 68
        I am curious weather the ccfl's or inverter might be the cause since the screen flickers on the off 1 time when powered on near the center. I should also note that the person I received this tv from said it was damaged in a lighning storm
        • proaudiosoft
          • Apr 2012
          • 68
          bump
          • proaudiosoft
            • Apr 2012
            • 68
            should the tv stay powered on with inverter disconnected?
            • proaudiosoft
              • Apr 2012
              • 68
              Any input on what to check would be so appreciated
              • proaudiosoft
                • Apr 2012
                • 68
                bump
                • proaudiosoft
                  • Apr 2012
                  • 68
                  been a long while. just pulled this tv out from the basement again. I would love to get it working. I do not seem to have 345v (yes i do, disregard this)***EDITED) that i am supposed to. tv powers on, blinks green 15 times (as before, still the same ), then powers off. Any help would be so appreciated.
                  • proaudiosoft
                    • Apr 2012
                    • 68
                    Ok, so i have resurrected this thread. I still have this tv, same problem, never fixed yet. All voltages seem to be good on the power supply, my previous comment of missing 345v was in error, its there still. A couple voltages seem to be a couple volts higher maybe, but they all seem to be present. I am tempted at this point to order a used mainboard off ebay and give it go. does anyone have any input on anything I might check before doing so? I would like to power this supply on with the mainboard disconnected, but this particular mainboard has 2 cables coming from the supply, and both seem to be necessary for powering on with backlight operating and such. Any advice or guidance greatly appreciated.
                    • proaudiosoft
                      • Apr 2012
                      • 68
                      Fixed this on my own.
                        It would be useful to say HOW you fixed it, for others in future.
                        • proaudiosoft
                          • Apr 2012
                          • 68
                          Replaced digital mainboard, no luck. Replaced inverter board, success. Fooled me because I would have thought TV would have stayed powered on with inverter removed from the circuit.
                            • 12276
                            • U.S.
                            #33
                            Hi, I am new to these forums, I have repaired several tv's , Just wanted to see if I could get some help on this one. The powerboard (and other boards) have no visible bad caps. Power seems ok at any marked voltage points on the power board. The inverter visibly looks ok too. When power is pressed the green light comes on, flashes 15 times, then back to red. I was thinking the problem is possibly the inverted since the screen just flashes very briefly then off like a second later. but If I unplug the inverter from the circuit, the TV still flashes green 15 times green then off. does this mean its not the inverter, or the tv is going into protection mode again without it?
                            And insight or help I would so much appreciate. I can post any pictures if need be. Thanks, Roger
                            you were on the solution in your first post,
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • frannyjunk
                              Hisense 40H4F no backlight but turns off after splash screen
                              by frannyjunk
                              So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                              TIA.
                              09-24-2025, 10:59 AM
                            • JunkmanJimbo
                              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                              by JunkmanJimbo
                              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                              No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                              Please help. Thanks in advance!
                              08-12-2025, 11:45 AM
                            • Rav_tangle
                              MacBook Pro 2011 turns on with keyboard light , screen dead
                              by Rav_tangle
                              Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                              I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                              Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                              is this...
                              05-31-2024, 04:09 PM
                            • reformatt
                              by reformatt
                              07-31-2025, 08:37 PM
