Kogan KALED553D1A vertical lines and pixelation
  • antirealm
    • 14
    • australia
    Hi everyone, this is my first thread but I've found this forum useful before, thanks to it I now have a working 40" LCD for $30. Yippeee!
    I'm back now with another one, I've looked into it as much as I can and I'm guessing its a t-con board problem. But before I order a new one, I wanted to get your thoughts on these photos.
    On black screen we see vertical lines evenly spaced across whole screen. with a few other green pixels. Another photo has what the "No signal" message looks like, and on the final photo we see the menu with all funky colors.
    The T-con board I'm looking at getting is a CMO model number V546H1-CS2
    Thanks for your time. Pat
    Re: Kogan KALED553D1A vertical lines and pixelation
    I have seen this before on cheap TVs. It was a loose cable between the main board and T-con board.
    • antirealm
      • 14
      • australia
      I checked that they seem ok, any other ideas?
        Can we see some pictures of the chassis layout?
        • antirealm
          • 14
          • australia
          yeah sorry for the late reply, its not the greatest photo. :/ thanks man
          • antirealm
            • 14
            • australia
            ok, I've jiggled LVDS1 and LVDS2 while tv was on, seems to change the picture but never fix it.
              Have you removed and plugged back in all of these connectors?
              • antirealm
                • 14
                • australia
                yeah i did, nothing.
                  When you fiddle with those the lines change and go away briefly?
                  • antirealm
                    • 14
                    • australia
                    they changed color and what not but never left. they do go away when i go to menu but the picture is still scrambled as per screenshots.
                      Tough one. I'm thinking the cables are defective since you really should see no change when wiggling them -- assuming the cables stay seated. Either that, or the main board is defective. It's hard for me to be conclusive -- sorry...
                      • antirealm
                        • 14
                        • australia
                        thanks for your time anyway. is there an easy way to replace the cables?
                          You can contact an ebay seller of the parts for this TV. If they have broken up this TV they may be able to sell you the cables. Alternatively Kogan may be able to supply them directly, though as they are simply a rebadge factory (buying from Chinese manufacturers and simply supplying their logo and specification), I have my doubts.
                          • antirealm
                            • 14
                            • australia
                            ok thanks. one last question, do you think its more likely to be the main board and not the t-con board that is broken?
                              Is this a TV which has motion interpolation? e.g. 100/120Hz/200Hz/240Hz?
                              • antirealm
                                • 14
                                • australia
                                yeah 100hz
                                  I know earlier Samsung-based TVs put the motion interpolator on the LCD t-con. That could be bad. Can we see a picture of the T-con, with the shield removed?
                                  • antirealm
                                    • 14
                                    • australia
                                    i will have to get the photo later but this is one i found on the net if it helps: http://assets.shopjimmy.com/media/ca...064376-top.jpg
                                      No motion interpolator on there, then; that's just an ordinary T-con board. The motion processing is done on the main board then.
                                      • Stanley1843
                                        by Stanley1843
                                        06-29-2024, 11:54 AM
                                      • Daren87
                                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                        by Daren87
                                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                        08-13-2023, 03:25 PM
                                      • Falki
                                        Colorful LCD Vertical Lines on Samsung ue55es8090
                                        by Falki
                                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                                        A similar issue has been posted as well but also with no actual response ...
                                        08-12-2025, 04:19 AM
                                      • gpo23
                                        Sony KDL-40V3000 - Vertical lines
                                        by gpo23
                                        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                        With the new t-con the color are good but there are vertical lines on all the screen :
                                        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                        Is there a way to fix the vertical lines on the new t-con ?
                                        Thank you for your help
                                        gpo23...
                                        10-04-2023, 09:11 AM
                                      • x_orange90_x
                                        TCL 50S535 bad tcon or panel issue?
                                        by x_orange90_x
                                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                        03-29-2025, 11:02 PM
